20 Most Recent Bosch Z25-1-240v 292177 034837-111 Board Questions & Answers
2answers
My 3x21 Bosch belt sander will no longer adjust enough to track properly. Is there a fix?
There are a number of reasons why a belt sander will fail to track - Poor quality belts. Physical damage (dropped). Uneven wear of rubber drive roller. When one becomes troublesome it can take a deal of sorting. Best idea if there is no obvious reason is to start by trying an OE belt.
7/13/2020 7:27:51 PM • Bosch Tools &... • Answered on Jul 13, 2020
I have a Bosch model DVS 3107 that runs fine if I am not placing it on the sanding surface, but bogs down when i start to sand. Disassembly revealed that both armature bearings are free. Thoughts?
Just to clarify ..the bearing at the bottom nearest to the sanding pad is good? Also does it just stop and make a humming sound when in use ?
2/4/2018 4:27:35 PM • Bosch Tools &... • Answered on Feb 04, 2018
Can i turn my bosch pex 115a grinder into a sander
Isn't this a random orbital sander.
9/28/2017 6:29:33 AM • Bosch Tools &... • Answered on Sep 28, 2017
?My Bosch 3107DVS sander slows down while sanding almost to a complete stop. Any ideas
Make sure that you have a good set of brushes in there. If so and it continues to happen then the motor is no longer drawing the amount of current it needs to function properly, because it should not slow down like that.
2/15/2017 11:03:04 PM • Bosch Tools &... • Answered on Feb 15, 2017
What type of oil goes in the bosch hammer drill crank case
Not for the little handtools there are 2 different greases depending on the model. But the average hand 5kg Bosch hammer 1 615 430 019 oil 1000ml
1/7/2017 9:52:41 AM • Bosch Tools &... • Answered on Jan 07, 2017
0answers
Belt broken on bosch rotak34
OOOOH NO BOSCH PEOPLE WHO READ THIS QUESTION i know we are a few years later but that have bought for a few years ago English qualcast tools was taken over by BOSCH Beware of the high tension behind the pully of all Wear safety goggles. if the motor is split do not tension on a half open motor because the bearing in one site of the pulley breaks by the to high tension the motor parts must first be brought together both half parts and the belt between that must be tensioned by a good long piece like a very great screwdriver inside the great pully to tension the belt on the pulley , !!! a hell of a job .
5/20/2016 2:54:50 PM • Bosch Tools &... • Answered on May 20, 2016
Defect battery loader bosch AL60DV
5/20/2016 2:16:24 PM • Bosch Tools &... • Answered on May 20, 2016
Bosch Z25-1-240v 292177 034837-111 Board Logo
0 questions posted
Top Bosch Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Tools & Hardware - Others
Most Popular Question
drill stopped working but still power
  • Tools & Hardware - Others
