20 Most Recent Compaq iPAQ H3830 Questions & Answers
Hi.there might be a damaged on your usb itself or usb port because it will not be recognized and read by the driver.
Compaq iPAQ... | Answered on Aug 01, 2011
hi :) here have a web for unlock,maybe can help u. good luck.. www.unlock-zode.com
Compaq iPAQ... | Answered on Jul 07, 2010
with most devices id just try the default password of 0000
or just put in as many 0's it will let you or try 1234 or type up as many times it will let u, so if u can enter 6 #s then enter "123456"
good luck.
those are the codes you should try to unlock it,
(they are default codes so if it was ever changed int he past it wont work)
Compaq iPAQ... | Answered on Nov 08, 2009
The 3835 did not have WiFi capability so you can't get online. Probably not worth messing with unless you're a real techie. I think there is a distro of Linux that can run on it if you want to play with that.
Replace e-prom.
Compaq iPAQ... | Answered on Mar 10, 2009
HOLD DISPLAY BUTTON ON REMOTE UNTIL LOCK GOES AWAY
Compaq iPAQ... | Answered on Feb 13, 2009
Its ok..just switch off ur child lock..........
Compaq iPAQ... | Answered on Feb 02, 2009
hold the display button down for 3 seconds
Compaq iPAQ... | Answered on Nov 09, 2008
use wired Ethernet, so it works. easy.
wifi is far more complex.
best is to own the router, you have.
then login to it and set it up for wpa./wpa2
wep off.
and a nice password for wifi so others cant hack it. in the hood.
then use those credentials all all your toys. xbox, PCs and cell.
that is the best way
the access point is covered in you manual for the router
there is AP button there, you push.
the PC in question my guess is the drivers are no good.
missing wrong, or corrupted.
no PC full model stated.
no OS stated
no router stated.
so answers will be weak to wrong,.
Compaq Computers... | Answered on Jan 20, 2020
Start your web browser,
find options, open options.
Find and open search.
On this page you will see
"Use the address bar for search and navigation"
and
"Add search bar in toolbar"
which puts a separate window next to the address bar with search written in it..
Choose which one you want to use
Go down to one click search engines.
You will see a number of search engines in a box usually ticked.
I use a search engine called Duckduckgo because it does not keep any data on me...
under the search engines box there is a line in blue "Find more search engines".
Click on the blue line and you will see a list of different search engines, click on one and a new page will open up and you follow instructions to install the search engine.
In she search engine box, if you do not want use one of engines just un-tick it
Hope this helps
Regards
Geoff
Compaq Computers... | Answered on Jan 11, 2020
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Compaq Computers... | Answered on Jan 06, 2020
Google
make model manual
They are all online. It _may_ be an eject button
Replace the CMOS (Complementary Metal-Oxide Semiconductor) battery to ... Turn off and unplug the netbook before replacing the battery. ... Press both orange eject buttons simultaneously, and use a spudger to pry off the back case. .... Tablet · Phone · Laptop · Repairable Products · E-waste · Recycling · Manufacturing ..
Compaq Computers... | Answered on Dec 26, 2019
Check this:
http://diy-ksoft.com/arduino/578-28-inch-tft-lcd-touch-screen-module-uno-expansion-board-for-arduino.html?search_query=LCD+arduino&results=114
There are a lot of touchscreens for arduino. Also if you want to keep it firmware compatible with what you have, you need to know the model and the interface type for it to get a new one that yill match yours.
Without further details is not possible to help you more....
Regards,
L. Coelho
Compaq Computers... | Answered on Dec 20, 2019
You stated an issue about playing/viewing AVI files on your computer?
I would suggest to go ahead and download an AVI file converter(w/c you can search via google or download via Filehippo.com)or get an AVI viewer/Player
(e.g. VLC etc./can also be searched/downloaded via gooogle.com or FileHippo.com)
Hope This Helps.
Thanks,
FixerDelta
Compaq Computers... | Answered on Nov 20, 2019
A dvd burner will burn anything you tell it to burn, the things is you need certain programs to see what the extension was that you burnt.
EX- if you burn a DIVX file, windows media player won't see it, but it will see a WMP file.
The most important thing is the burning software, makes it easy to burn boot, ISO files, video.
But like I said, a DVD burner will burn anything you tell it to burn.
Compaq Computers... | Answered on Nov 06, 2019
You must have got a disc having samsung kies,which is a pc suite for samsung mobile phones.If not click here to download pc suite for your phone.This link will take you to samsung support for GT-S3310.
Compaq Computers... | Answered on Sep 19, 2019
Compaq iPAQ H3830 Logo
17 questions posted
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iPAQ Compaq
  • iPAQ Compaq
Most Popular Question
telefunken ttv 2126 fac
  • Computers & Internet
