20 Most Recent
Compaq iPAQ H3650 Pocket PC Questions & Answers
Responce
turn off the unit, and then turn it back on. If this does not help, reset your nuvi.
1. Disconnect the device from external power.
2. Press the Reset button on the bottom of the device
3. Connect the device to a power source.
Reversed image
Y have a similar case, after replacing the LCD screen of one of my customers. The image is upside down and mirrored. We are going to test a new panel.
I'll let you know.
Mirrored image IPAQ 3650
Could you write down the part number for the old and new screens to check for compatibility?
Regards,
Internet Explorer for IPaq 3650
I'm not sure if Pocket PC Explorer is like the full Explorer version, but if you go to the Internet Options Control Panel, select the Advanced Tab, Scroll Down to the Multimedia Options and there are selection options for showing pics, playing sounds, etc. Hopefully, Pocket Explorer is similar and all you need to do is activate the option to show pics. Good Luck!
Password Sync
uninstall ActiveSync and all of its remianders (for details see here:
http://www.pocketpcfaq.com/wce/activesync3.1remove.htm )
Then make a new install of AS.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
How to fix 1780 disk 0 failure
bad hdd.
- buy a new hdd.
- buy upgrade to SSD
- buy it in a PC store like Bestbuy
- buy it at ebay , amazon or 1000s of online stores (googled)
- the reload the OS.
- or have a shop fix your PC and avoid all this , work.
