20 Most Recent Generac 6051 Guardian Series Air-Cooled 10kW 120/240V Single Phase Steel Residential Generator with Nexus Smart Switch Questions & Answers
The brushes on Generac automatic units are most likely not lined up with the slip rings and will wear down and burn out very fast. There is no way of checking this during assenbly because they are hidden from view and the generator has to be dismantled to be able to replace them. It's an extremely poor design and Genrac should face a class action lawsuit for producing this piece of junk.
Generac 6051... | Answered on Apr 23, 2013
Regarding the advice about "Flashing" a generator.
Do you people even know what that means?
What you are doing is messing with the capacitor that is part of the voltage conversion. Likely you are burning any shorts out of the capacitor. Has noting to do with the fields or coils or rectifier.
So if you are having issues then test the capacitor and replace it.
Try your flashing and see if you don't fry the rectifier.
It amazes me that people will blindly follow something they don't understand "hoping" that something good will happen.
But if a new generator is what you want then give your old one away instead of trashing it.
Generac... | Answered on May 13, 2020
During engine cranking and operation the controller receives AC
voltage and frequency signals from the ignition magneto via Wire
18. Should the speed exceed approximately 72 Hz (4320 RPM),
the controller's logic will de-energize the "run relay" (internal to
the controller). The relay contacts will open terminating engine
ignition and closing the fuel shutoff solenoid; the engine will
then shut down. This feature protects the engine and alternator
against damaging over speeds. During cranking the RPM signal
generated by the magnetos is used to terminate engine cranking.
Generac... | Answered on May 09, 2020
If you have a Generac Generator which fails to start during a power outage and gives an Error Code 1518 - RPM Sense Loss you can try and manually get the generator restarted very simply. ... The generator should wait 5 seconds and then try and auto-start up to 3 times.
https://www.justanswer.com/small-engine/bwmwi-working-generator-generac-protector-qs-38kw.html
Generac... | Answered on Mar 25, 2020
it is not producing voltage...
Generac Air Cooled Generators - Ziller Electric Inc ' Interactive Generac Generator Forum
https://www.google.com/search?q=generac+overspeed+fault&rlz=1C1OKWM_enUS816US816&oq=generac+overspeed+fault&aqs=chrome..69i57j0l6.5183j0j8&sourceid=chrome&ie=UTF-8
Generac... | Answered on Mar 11, 2020
i suspect you need a new controller. try asking here. read the rules before posting https://www.zillerstore.com/?forum=705132
Generac... | Answered on Dec 18, 2019
If you want to have a new diesel generator set in future, please visit the website for your reference: https://starlightgenerator.en.made-in-china.com/
Generac... | Answered on Dec 10, 2019
You can ask your supplier or check according to the maintenance manual.
Generac... | Answered on Nov 30, 2019
If you need to have a new diesel generator set in future, maybe you can contact [email protected] They are a manufacturer of diesel generator set for more than 43 years.
Generac... | Answered on Nov 05, 2019
If you need to have new diesel generator set, maybe you can contact [email protected]
Do you have maintenance manual? When you buy the generator, it must have manual. If the manual do not say about it, you are better to contact your supplier, then you tell details with them. Because different situation, will use different solutions. If you need to purchase new diesel generator set infuture, maybe you can visit : wwww.dieselgeneratortech.com, they have focused on high quality generator for 40 years. Or by email: [email protected]
Generac... | Answered on Oct 30, 2019
Check "F1" fuse.
If fuse is good, check voltage at battery.
With either utility power present or generating running, the voltage at the battery should be >13VDC. Any reading less than 12.7VDC is battery voltage and indicates a failed charging circuit.
Generac... | Answered on Oct 23, 2019
Generac 6051 Guardian Series Air-Cooled 10kW 120/240V Single Phase Steel Residential Generator with Nexus Smart Switch Logo
Popular Tags
7 questions posted
Top Generac Electrical Supplies Experts
Bill Johnson
Fahr Quad
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Generac Electrical Supplies
Most Popular Question
under voltage alarm shutdown generac 10
  • Electrical Supplies
