20 Most Recent Kipor RV Generator Sinemaster IG3000 Questions & Answers
Your oil level sensor is bad. It needs to be replaced. If you unplug the wire leads to the sensor you may get the generator to run, but you'll have no low oil level/pressure protection. The oil level sensor is on the engine crankcase usually near the oil level dipstick. You'll likely see a small sensor with a couple of wires attached to it. To replace it, you'll need to drain your engine crankcase before removing the sensor.
Kipor RV... | Answered on Mar 07, 2016
first check the circuit breakers if there ok the problem is inside like over heated parts
Kipor RV... | Answered on Nov 17, 2012
The DC output for battery charging is from the engine alternator and is completely independent from the generator inverter.
As this is an inverter unit the typical polarization techniques for standard generators will not apply.
The ouput indicator being lit means the inverter input output should be good. This further implies a circuit disconnect state at the outlets. Try pressing the overload reset switch to make sure it is not in an odd state.
Kipor Electrical... | Answered on Sep 11, 2020
https://www.youtube.com/watch?v=EfX1ChhzVQU
Kipor Electrical... | Answered on May 14, 2020
Request the wiring diagram from Kipor.
Kipor Electrical... | Answered on Feb 24, 2020
Do you mean your Kipor generator? Or anyothers?
Kipor Electrical... | Answered on Dec 28, 2019
You can check according to the manual operation.
Starlight power series diesel generator set power range is from 20kw to 3000kw, if you are interested, please contact us at website: www.dieselgeneratortech.com
Kipor Electrical... | Answered on Nov 30, 2019
Starlight Power diesel generator set power range from 20kw to 3000kw, if you are interested, visit our website: www.dieselgeneratortech.com
If you need diesel generator set in future, contact us at website: www.dieselgeneratortech.com
A diesel generator set for your reference: www.dieselgeneratortech.com
Kipor Electrical... | Answered on Nov 27, 2019
A diesel generator set website for your reference: www.dieselgeneratortech.com
Oh, there are many people say the generator can not supply power. Maybe the fuel is not enough or other problems. I recommend you to buy diesel generator set in future, its quality is better and can use for a long time. A website for your reference: www.dieselgeneratortech.com
If you need to purchase diesel generator set in future, please vsit for reference: www.dieselgeneratortech.com
If you need to purchase diesel generator set in future, please visit at www.dieselgeneratortech.com
Kipor RV Generator Sinemaster IG3000 Logo
Popular Tags
6 questions posted
Top Kipor Electrical Supplies Experts
Vernon Taylor
Robert Wooley
Robert Wooley
ray gallant
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kipor Electrical Supplies
Most Popular Question
kipor generator starts ok but will not
  • Electrical Supplies
