20 Most Recent
Labtec LCS 3210 Computer Speakers Questions & Answers
I'm looking for a male
http://www.ebay.com.au/itm/DIY-6-5mm-Male-Plug-Mono-Audio-Adapter-Connector-Gold-/170560976732?pt=AU_Electronics_Accessories_Wires_Cables&hash=item27b639f75cEbay $1
You might get these on Ebay
im not sure which country you are in this might guide you to one
you could get this on Ebay
if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal
login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration
password ,bank card /credit card,phone numbers home/mobile ,email adress
and a postal adress
be very specific when you
type in the search
always ask questions?
before you make a purchase and keep the email/s for security reasons if the
item arrives and its not as described
you will even see the
pictures of your item so you cant make a mistake and get them home delivered
try swapping the speakers
around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
or you might have to clean
the dust from your computer dust causes static which causes your computer to
overheat and all sorts of problems
be sure to wear an anti
static earth strap before touching anything inside your computer try
cleaning your computer of dust using a fine air blower from a compressor making
VERY sure that there is no MOISTURE in the air line specifically around the CPU
central processing unit and your SOUND CARD dust causes static to build up in a
computer causing it to overheat any many other problems
hope this helps
What's the part number for the operational amplifier ,DC 15dc of LCS 1024
why not photo the IC, and show that.
for 10x better answers.
not told what car is came out of or what the OBJECT did. (PCM/ECU/BCM ,etc?) <<< vast on cars/trucks\
many PCB or Modules the ICs are some or all , contract parts
and the number on top is secret contract Part number.
ahhhhhh it is not a CAR at all it is
LABTEC LCS-1024 AMPLIFIED COMPUTER SPEAKERS
moving you now to computers stuff
Can you hook up a Labtec 2424 sub to a smart TV
If you are looking for the top security companies in London that provides its customer with remarkable security services. Check out this site for security services https://www.urbansecurityguards.co.uk
