20 Most Recent Taylor Digital Cooking Thermometer Questions & Answers
That means the temp is higher than the unit is able to detect. If it has been exposed to very high heat then it is damaged. It may still have a bad sensor.
Taylor Digital... | Answered on Jun 20, 2016
The Clock display is located at the top of the base unit's LCD screen. The clock has alarm and snooze functions.
A) Clock Setting
1. Press and hold the "SET" button on the back of the base unit for 3 seconds to enter Clock Setting Mode. The year digits flash in place of the clock digits.
2. Press the "+" or "-" button to change the year. Press "SET" to confirm. The month digits flash.
3. Press the "+" or "-" button to change the month. Press "SET" to confirm. The date digits flash.
4. Press the "+" or "-" button to change the date. Press "SET" to confirm. The Day/Month ("D M") or Month/Day
("M D") selection flashes.
5. Press the "+" or "-" button to toggle between Day/Month and Month/Day format. Press "SET" to confirm. A language selection flashes under the "DAY" icon to the left of the clock digits.
6. Press the "+" or "-" button to toggle between language selections*. Press "SET" to confirm the displayed language. Time zone offset digits flash in place of the clock.
7. Press the "+" or "-" button until the correct time zone offset** appears (-12 to +12). Press "SET to confirm the displayed time zone offset. "12 Hr" or "24 Hr" flashes.
8. Press the "+" or "-" button to toggle between 12 and 24 hour clock mode. Press "SET" to confirm.
The hour and minute digits reappear. The hour digits flash.
9. Press the "+" or "-" button to change the hours. Press "SET" to confirm. The minute digits flash.
10. Press the "+" or "-" button to change the minutes. Press "SET" to confirm. The hour and minute digits stop flashing. The clock is set.
Taylor Measuring... | Answered on Nov 04, 2019
Change the batteries. LCD displays will appear very dim and hard to read except at certain angles is the batteries are low.
Taylor Measuring... | Answered on Sep 07, 2019
Howdy! Good news... go to this site for detailed instructions...
https://fccid.io/WEC-1502/User-Manual/User-manual-2726076
if that fails contact the company 'customer support'.
Taylor Measuring... | Answered on Dec 19, 2018
First, I'm not a Taylor representative.
* Check your warranty. Call for support
* Contact; 1-800-289-0944
* WWW.taylorusa.com
*** The following is for information only.***
* Are you sure about the model "5212"?
* LED Meat Thermometer; https://www.youtube.com/watch?v=v6okAYWECvQ
* Manual (1487); https://www.wholesalepoint.com/documents/Taylor-1487.pdf
* Unboxing (1487); https://www.youtube.com/watch?v=SagK4czbaF4
* True Temp; https://www.youtube.com/watch?v=S9mLBcW2R_k
Aloha, ukeboy57
Additional (related) Information;
* Dial style; https://www.youtube.com/watch?v=OgrSqFR0x9o
* Brochure; http://taylor-enviro.com/media/lit/2014-ProKitchen-SellSheet.pdf
* Specs; http://www.lesman.com/unleashd/catalog/thermome/Taylor-dial-thermometers/tay_pockets.pdf
* Using meat thermometers; https://www.bhg.com/recipes/how-to/food-storage-safety/using-a-meat-thermometer/
* Calibrate; https://www.youtube.com/watch?v=gfx2zJP0QTw
Taylor Measuring... | Answered on Aug 18, 2018
In vigorously boiling water, it should read 212 (at sea level) or a little less, depending on your elevation - lid on or not. Maybe the water wasn't boiling fast when you got the 200 reading. Make sure the probe tip is not touching the pot sides or bottom.
Taylor Measuring... | Answered on Dec 30, 2017
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station.
1541 WeatherGuide Wireless Weather Forecaster with Barometer
Taylor Measuring... | Answered on Jan 06, 2016
Hit reset next to batteries to have it sync with outside temp sensor. Push mode button to scroll thru date, time. Use up and down button on back to adjust numbers.
Taylor Measuring... | Answered on Mar 03, 2015
Taylor Digital Cooking Thermometer Logo
2 questions posted
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Taylor Measuring Tools & Sensors
Most Popular Question
thermo temp flashes hhh thermometer
  • Measuring Tools & Sensors
