20 Most Recent
Labtec LCS 150 Computer Speakers Questions & Answers
Labtec lcs 150 disassemble
Three screws (each speaker). One visible in the rear at the top, two more hiding in the battery compartment. Good luck. Broken wires can be re-soldered. Speakers may be replaceable (though in this disposable age your sources are drying quickly). Otherwise, off to Amazon for new speakers.
Hiw many mA does the adapter for labtec lcs150 speakers need
6V DC 200 MA; plus shell, minus center pinaka, Panasonic AC Adapter Model No. RP-65A or equiv..You want to make sure the plug at the speaker end is wired properly: + on the outer barrel and minus on the center pin (the adapter will have a little graphic for verification purposes). If so, your 500ma adapter should work fine. The voltage might be a little high but nothing the speakers cannot handle I would think.
Unable to get sound from speakers multimedia
you might have to uninstall then reinstall the sound drivers
if your computer came with a motherboard disk the drivers could be on it
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
I plugged in my speakers to Compaq Presiaro
Hello Debkopper, Hi!, No sound output can be several things. so lets do this one at a time.
No sound means:
1. mute or low volume setting. check your volume controls. If you can find the volume controls,
2. look at the lower right side of your monitor, (if you are using Windows7 or xp) you should see a speaker ICON. click it and set the volume. If you have no speaker ICON, then
3. you need the driver software to activate the sound section of your PC. if you have the CD of the PC motherboard, use the CD to install the driver. IF you have a SOUND CARD, locate the CD that comes with it when you purchase it. If the sound card comes with your PC. locate its CD driver.
4. NO CD, then browse the internet to download the driver software. Here are info of what you need jot this down..... the motherboard make and model. (If sound card then the make and model)
5. After download install the driver.
IF you cannot find the driver or simply tired to find what it is, BUY a USB type SOUND CARD. plug it on a spare USB port, then your done, instant sound!!!
I don't know where to
hello vivian10
your speakers should have a headphone jack, and your computer should have a speaker-in jack and a mic-in jack. plug your speaker jack into the jack on pc
What's the part number for the operational amplifier ,DC 15dc of LCS 1024
why not photo the IC, and show that.
for 10x better answers.
not told what car is came out of or what the OBJECT did. (PCM/ECU/BCM ,etc?) <<< vast on cars/trucks\
many PCB or Modules the ICs are some or all , contract parts
and the number on top is secret contract Part number.
ahhhhhh it is not a CAR at all it is
LABTEC LCS-1024 AMPLIFIED COMPUTER SPEAKERS
moving you now to computers stuff
Can you hook up a Labtec 2424 sub to a smart TV
If you are looking for the top security companies in London that provides its customer with remarkable security services. Check out this site for security services https://www.urbansecurityguards.co.uk
