20 Most Recent McCulloch Fg5700ak 5,700 Watt Portable Generator Like Questions & Answers
I have a mcculloch fg5700ak generator that will start when you choke it and it will idle until you push choke back in then it dies.
the carb needs to be cleaned I think the internal jets are plugged
6/10/2015 1:52:05 AM • McCulloch... • Answered on Jun 10, 2015
0answers
0answers
0answers
Generator not making electric
You have a faulty inverter board on the unit. I would warranty the generator in this case, or have the manufacturer send you out a replacement board to swap yourself.
10/18/2013 8:08:34 PM • McCulloch... • Answered on Oct 18, 2013
0answers
2answers
What's the valve specs for McCulloch FR6000MK generator with 11hp 4 stroke?
.010" inlet hot and .012" exhaust hot
4/7/2024 12:18:07 AM • McCulloch... • Answered on Apr 07, 2024
I need a repair manual for a McCulloch FG6000MK Generator
https://www.manualslib.com/products/Mcculloch-Fg6000mk-278219.html
6/23/2022 7:50:15 PM • McCulloch... • Answered on Jun 23, 2022
Have a McCulloch generator FG5700AK with a wenling jennfeng engine and am looking for the carburetor. Do you sale or know anyone who sales them? Thank you.
Ebay has the carb for under fifteen bucks. Want to add a note on calibration or recalibrating when replacing the carburetor. McCulloch FG6000 or FG5700, Wen, and many more use the same wenling jennfeng (wenling jenn feng) engine. On the FG6000, FG5700, and others, you'll see both an idle speed screw and an idle mixture needle valve on the carb. On top of the engine, you'll see the governor sensitivity spring tensioner screw top center of engine. First, loosen the governor spring tensioner screw until its loose with spring totally collapsed. With no load, adjust carb idle to 60hz-62hz using a multimeter. Now adjust the carburetor needle valve to the highest smoothest idle speed (highest possible hertz on the multimeter). Then readjust carb idles speed screw back to 60-62hz max, nothing higher. Finally, adjust the governor spring tensioner screw to calibrate governor sensitivity; loosen for less governing, tighten for more governing, and too tight will take away and defeat idle speed screw on carb. It's a delicate balance, takes some work, but when finished the generator should always maintain 60-62hz under any load condition.
9/27/2021 10:06:11 PM • McCulloch... • Answered on Sep 27, 2021
What size capacitor goes in a McCulloch Generator FG5700AK 5700WATT
Multiple choice depending on which power head ( alternator). Try generatorguru. https://www.generatorguru.com/capacitor-16234087/
9/16/2021 8:07:26 AM • McCulloch... • Answered on Sep 16, 2021
McCulloch Fg5700ak 5,700 Watt Portable Generator Like Logo
Popular Tags
17 questions posted
Top McCulloch Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • McCulloch Electrical Supplies
Most Popular Question
generator not making electric
  • Electrical Supplies
