20 Most Recent
Creative Labs ESS 1938S Sound Card Questions & Answers
Linux Driver
You can use the defualt for crative works great in unbuntu or change out your sound card as its too old anyhow just two suggests dont shoot the messanger be nice a rate me baised on how fast i reponeded as soon as i saw you problem with was 6-19/2009 @ 11pm pacific Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Driver
You did not specify the problem here, friend. But I think the problem might be the sound or the input microphone or headset...
If you hear no sound or voice you suspect first the headset or the speaker. Try to use good speaker and or headset to know if there is no problem within those device. If you hear nothing...the problem is the sound card and you need to replace the sound card with new
I want drriver for sound
Hi
Click hear to download the sound driver, extract the download file and go to setup.exe or install, after installation reboot your computer.
Cheer
No sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
