20 Most Recent Mitsubishi 915p026010 Wd-62627/Wd-62628 Projection TV Lamp Questions & Answers
should be in the manual. Or you can look on line for Mitsubishi model wd62627 owners manual download.
Mitsubishi... | Answered on Sep 09, 2014
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, or the LED light stationery; the main board is faulty.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview/
Mitsubishi WD... | Answered on Jul 10, 2018
Basing the replacement of the board on the clicking sound of a relay trying to close is not a safe bet. The first thing you need to do is check the bulb. Then there is a ballast board and then the Power supply board. Parts might be hard to find. Use the website I listed to see what part numbers are then google it or look on eba or amazon for those parts. Mitsubishi WD 60C8 TV Parts
Mitsubishi WD... | Answered on Jan 18, 2018
Most likely a fuse blew when the lamp blew, there is internal fuses on the power supply board on these mitsubishi's, if the fuse is ok though then most likely another component somewhere failed.
Mitsubishi WD... | Answered on Jan 02, 2018
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mitsubishi WD... | Answered on Mar 27, 2017
Replace your lamp. Make sure its a real Osram bulb and not some cheap knock off. These folks have Osram bulbs and a 6mo warranty. Projector Lamps and TV Lampson Sale ProjectorLamps com stocks Superior...
Mitsubishi WD... | Answered on Sep 30, 2016
If your set worked well (no lines, maybe only white or black scattered pixels) before you replaced the DLP chip, then your problem could be that the DLP chip did not get seated properly or the cam screws were not tightened enough after replacing the chip. The DLP chip must be seated properly in its socket or else line and column lines will be seen. There is also the possibility that the DLP chip is defective or suffered static damage while being handled during the installation. Hope this helps.
Mitsubishi WD... | Answered on Aug 31, 2016
Mitsubishi 915p026010 Wd-62627/Wd-62628 Projection TV Lamp Logo
6 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
wd62628 factory reset button
  • Televison & Video
