20 Most Recent
Dell Inspiron 3800 Celeron 500MHZ Processor (CPU) - 569KW Questions & Answers
I NEED TO UNLOCK AN OLDER MODEL DELL INSPIRON 3800
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabledGo to:
http://dell-inspiron-3800-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Modem is not detected by win98se. driver from dell
Hi, Thanks for using fixya.
Turn off the computer then open the computer case. Remove the modem look on the chip side, it will have the name of the manufacturer on the largest chip. You can also copy the fcc number and search google for it.
Terry
When istart my computer it starts to boot then
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to your hard drive
hope this helps
Caqn i put a 700Mhz Dell Pentium III in the same
No, you cannot exchange them. I was not able to determine what socket your notebook uses, but the 500 Mhz mobile Celeron was only available in two formats. One was Socket 495, which has no Pentium III processors available (only Celeron). The other is BGA2, which is not a socket at all, but is soldered onto the motherboard and is thus virtually unremovable.
A friend gave me a
Press either delete or f2 during the boot up process to enter BIOS you can change or remove your name&password from there
good luck
Was working on my laptop and it shut down now it
I guess the problem is with your hard disk. The hard disk might have got corrupted because of some bad sectors or some virus. Try going for a XP reinstallation. That will almost fix your problem. If the problem still persists, Then am really sorry to say, you should go for a product replacement which is not advisable you may happen to lose the data in your old hard disk. The service center ppl will not care abt your data and they wont take backup for you as well. So try to go for XP reinstallation.
I have three seperate physical hard disks (c:, d:
okay you will need to put a boot record on the other drives see the boot record is on C to boot from D and so forth so what you can do is this from command prompt type is "sys mbr", if that does not work you will need to remount the drive using a disk manger software like spinright, and so forth or simply creating a bootable partition under disk admiistration under the control panel.
I hope this does help.
Thanks for using fixya.com please do leave postive ratings for your free answer today. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
PCI device not responding
hello, it would be better if u mention the type of PCI devices. any way, i think there must be other free pci slots on ur mainboard. try inserting the device to other free slots. Or use the same device to other working pc. hope it helps.
Dell inspiron 3800 has power issues. I tried 2
you have a shortcut circuit in your laptop. most probably power diodes that is in entering conector of adapter in your laptop have gone or some of rezistances located there. you have to service laptop.
No boot sector on hard drive
FIXBOOT writes the "boot sector" to the specified partition.
FIXMBR repairs or replaces the master boot record of the disk.
You will also want to ensure that your partition is active, because
Ghost will not make a partition active unless you do a sector-by-sector
backup and complete restore.
Here's what to do...
Boot from the XP / 2000 CDROM and allow the setup to begin. Once the
beginning files are copied, you will be asked to Install Windows or use
the Recovery Console. Please choose "r" here, to run the recovery
console.
You will now type in the following commands when the prompt appears:
chkdsk /f
* This will repair any obvious file system damage, which could complicate things.
diskpart
* This will run the XP disk partition utility. We will be checking to
see if your partition looks OK. If you see your partition, and the
information diskpart provides appears correct, then that's a good
thing. :)
Press [ESC] to exit Diskpart, when everything looks peachy.
fixboot
* We'll write a new boot sector, so the computer knows how to boot the computer
fixmbr
* We'll write a new boot record, so the computer knows how to boot Windows
You should be taken care of. If it still does not work, you may need to
delete your partition(s) using diskpart, then recreate the partition(s)
(using diskpart, again).
No boot at all
could be a variety of hardware issues ... if you have a modem card remove it first ... leave the battery out as it is not required to operate the laptop as long as you have ac power ... leave all the ram chips out as most laptops have some ram built in ... remove the harddrive and any other internal drives ... also disconnect anything external ... network printers etc... after that yopu are into removing the keyboard and disconnecting the video ...but it gets a bit complicated if you have never worked on laptops before...
Display on laptop loose
Try tightening all the screws around the hinge area, if that is not the problem I am sure the actual hinges can be replaced for a fairly reasonable amount.
