20 Most Recent
Belling XOU590 Electric Double Oven Questions & Answers
Belling oven wont heat on any setting
Check if the timer is set? If that is okay, a failed element is the most likely cause. Disconnect the leads and check continuity with a test meter.
Belling Oven
is Not Heating
Up
You can test whether your
Belling oven is
heating up correctly by turning the
oven on, setting the
temperature and letting it sit for five minutes. If the
oven cavity is not hot when you open the door, it is likely that your
oven element is broken.
Belling Oven Not Working? Here's How To Fix it
