20 Most Recent Excelstor Technology J880 Hard Drive Questions & Answers
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation. Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
3/31/2017 4:35:08 PM • Excelstor... • Answered on Mar 31, 2017
Como configurar jumpers como master
Solution found here.
5/8/2011 9:16:32 PM • Excelstor... • Answered on May 08, 2011
Can we use Excelstor Gstor
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
3/20/2011 7:51:06 AM • Excelstor... • Answered on Mar 20, 2011
How to make the J880
you can read the jumpersettings here.
http://dl.dropbox.com/u/599106/Festplatte%2080GByte%20Excelstor%20J880.pdf
The file is in german. Comments are in english. Use only the red framed settings.
best regards
Josch
12/30/2010 7:10:14 PM • Excelstor... • Answered on Dec 30, 2010
How do yow find the jumper settings for ExcelStor
Your jumper settings are at the bottom of the page http://www.derpcfuchs.de/festplatten-jumper.html
10/17/2010 8:14:57 PM • Excelstor... • Answered on Oct 17, 2010
2answers
How to format excelstor hardisk?
For your specific operating system, assuming that Windows is running, locate Admistrative Tools -> Disk management.
You should see Disk 0 or Disk 1 with your Excelstor 80GB drive: if you do not have a partition, create one or more partition, assign drive letter(s) and then format using the context menu.
If you do not see the drive in the Disk Management screen, then your Bios has not been setup properly or your drive is not connected properly.
Hope it helps.
9/27/2010 6:09:05 AM • Excelstor... • Answered on Sep 27, 2010
Problem on formatting GstorPlus hard drive
bios maybe set to raid
7/23/2010 4:02:29 PM • Excelstor... • Answered on Jul 23, 2010
I have changed hard drive to ExcelStor Callisto
What error-message(s) do you get?
Access http://www.microsoft.com/downloads
and download Windows XP Service Pack 3,
and install it.
You do *NOT* need to install SP2 before installing SP3.
12/26/2009 6:52:36 PM • Excelstor... • Answered on Dec 26, 2009
Shows hard drive into 4 sections soon uses gb up
Use Partition Magic. It is software that will Re-Size, Merge and Create a hard drive partition. Here is the download link for you pal:
http://www.softpedia.com/get/System/Hard-Disk-Utils/Partition-Magic.shtml
I am sure this could help you a lot. Thanks..
12/18/2009 11:37:36 AM • Excelstor... • Answered on Dec 18, 2009
Pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
5/23/2009 11:41:22 PM • Excelstor... • Answered on May 23, 2009
2answers
System not detecting hard disk
Check the position of the master/slave jumper on the drive.
4/9/2009 12:47:29 AM • Excelstor... • Answered on Apr 09, 2009
J880-80 Gb---machine red only 33Gb
format the hard drive.
2/26/2009 9:44:26 AM • Excelstor... • Answered on Feb 26, 2009
I have 80 gb of
I am guessing it is an older machine. consider trying the following:
GO to  START - HELP AND SUPPORT - SYSTEM RESTORE - SETTINGS - SYSTEM RESTORE SETTINGS -SETTINGS - Try changing to SAVE LESS.
Maybe this is where all of your space went .
Also clean the HD: . START -  MY COMPUTER - rRight click HARD DRIVE -  DISK CLEAN UP - (AFTER THAT'S DONE) click TOOLS - DEFRAGMENT NOW.
12/18/2008 12:59:58 PM • Excelstor... • Answered on Dec 18, 2008
3answers
Cant install ubuntu 7.04 on Excelstor J880 SATA Drive
From what I know, both your motherboard and your hard drive work with Ubuntu. I would try the newest release, 8.04 (Hardy Heron).
Try setting the motherboard into AHCI mode rather than IDE mode (you should be able to change this under hard drive settings in your BIOS)
Also, the problem may be with your optical drive. Try swapping that out.  If you can't solve it from there, if you haven't already, try posting on the ubuntu forums.
12/1/2008 11:15:46 PM • Excelstor... • Answered on Dec 01, 2008
Date Code Information on ExcelStor Callisto 80GB drive label
yeah u can find on top sticker of hd.
11/26/2008 12:30:31 PM • Excelstor... • Answered on Nov 26, 2008
I have a 80GB disk, but only 30GB is a recognized partition by Windows.i need instructions
Most likely the problem is that you have another blank partition. The Microsoft disk management tool can probably solve this. This is a tutorial on how to use it. http://support.microsoft.com/kb/309000/
Let us know if this works out for you.
7/26/2008 10:22:38 PM • Excelstor... • Answered on Jul 26, 2008
Excelstor Technology J880 Hard Drive Logo
38 questions posted
Top Excelstor Technology Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Excelstor Technology Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Excelstor Technology Computers & Internet
Most Popular Question
yow find jumper settings excelstor
  • Computers & Internet
