20 Most Recent Dell Inspiron 1200 14.1 XGA LCD Display-320-4222 (3204222) CD-ROM Drive Questions & Answers
it sounds like you may have an updated driver that doesn't work with your machine. boot into SAFE mode. on a dell it is hitting the Del button for most of them as it is booting up. then choose safe mode. For other dells it is F1 or F2 you just keep hitting the button while its booting up until you hear it start to beep at you. then look for safe mode. while in safe mode you can then change the driver, but for those specifics you have to go to dells web site. http://www.dell.com/support/home/us/en/19/quicktest?c=us&l=en&~ck=mn
Dell Inspiron... | Answered on Dec 03, 2017
There are two memory slots on this model, but there is no "Onboard" memory. Without the memory that you removed, your laptop will not post. It sounds like a dead motherboard issue to me, especially since you have pretty much torn it down to barebones. Rarely, this can also be caused by the processor but it is less likely. Unfortunately, since you cannot keep it running, there isn't much chance of diagnostics. I hope this helped.
Dell Inspiron... | Answered on May 26, 2012
For that you need to check bios settings.
when you power up the computer press F1 or F2 or del ALt+F2 key to enter in bios.
then in advanced menu disable memory shadow then save settings and check.
If still same then may be your memory is not compatible with other memory check with only 1 RAM.
Also make sure RAM frequency compatible with your motherboard of computer.
Let me know if you need further assistance.
Thanks for using FixY.a
Dell Inspiron... | Answered on Aug 09, 2011
Yes, from what you describe, the screen is bad.
Dell Inspiron... | Answered on Feb 10, 2011
  • Hi, you can go into the "Control Panel" and make changes to the Power Saving Options, or Energy Saving. First from the "Start Menu" in the [Start Search] window, type: power, next scroll to find the "Short-cut' listing for {Power Options}, click on it to go to the next window. You'll be able to adjust the "Power Options," (Sleep, "Awake," or Hiberate, if available). "Let me know how things worked out for you by giving a "helpful rating"
Dell Inspiron... | Answered on Jul 07, 2010
Go to Start Menu>Settings>Control Panel> PowerOptions
Then go to the Advanced tab, Under Power Buttons, make sure "When I press the Power Button" and "When I press the sleep Button" are set to "Do Nothing"
Dell Inspiron... | Answered on Jan 28, 2010
Yes there is a battery that looks much like a watch battery on the motherboard.
Dell Inspiron... | Answered on Dec 10, 2009
Here is CMOS battery and how to locate.
Dell Inspiron... | Answered on Aug 23, 2009
Press "F8" while booting up. It should give you an option to go to safe mode.
Dell Inspiron... | Answered on Jun 29, 2009
I think you have CD RAM and DVD ROM i had also the problem of read dvd but i buy CD/DVD RAM Now my drive is working properly and successfully
if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and
DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data
to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
If your battery LED flashes or is solid Yellow or Amber color, this usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dell Inspiron... | Answered on Mar 31, 2009
Try starting your Laptop in safe mode,,,then do a system restore
Dell Inspiron... | Answered on Jan 16, 2009
Was the battery a Dell replacement? or was it a Chinese replacement battery?
Your charging circuit may have been damaged.
Windows has probably become corrupted,,,try using you restore cd,,,or starting in safe mode.
Windows has loaded improper video adapter drivers,,you need to install correct ones
Re-Install the wi-fi adapter drivers.
Dell Inspiron... | Answered on Dec 31, 2008
Sounds like you have a bad Stick of ram.If you have 2 sticks remove one then try to load the operating system.If that doesnt work replace it with the other one and try to boot.If you are not sure what ram is leave a comment and I will explain.If neither work buy a new stick of ram and that should take care of your problem.Rate me if this works!GOOD LUCK!
Dell Inspiron... | Answered on Aug 29, 2008
no.. its the backlight or the inverter.. both located at bottom edge of lcd under plastics.. the backlight is a mini fluorecent light tube in the lcd dotn try to fix it its hard. the inverter u can fix . inverter is easier and its 25$ in ebay
Dell Inspiron... | Answered on Jun 01, 2008
Computers & Internet Logo
27 questions posted
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
5 year old dell inspiron 1200 screen
  • Computers & Internet
