20 Most Recent
Dell Refurbished PowerEdge 2650 Server Questions & Answers
I have a working Dell Poweredge 2650 with 2 x Xeon
You should be able to do this by moving the drives all at once ALL DRIVES MUST BE PLACED IN THE SAME SLOTS 0,1,2,3,4, do not mismatch else it will be a nightmare ............HOWEVER BACKUP your data up if you are going this route,on paper it might sound like a winner,however not all that glitters is gold.controllers though they might be the same have different firmware which allow them to do different things,so if you are going to this the os drive raid 0 or 1 must be two seperate is drives.once this done,how is your raid set up for the other drives once you have a good back up to restore if there is any complication,move the over in the same order,remember POWER DOWN BEFORE YOU ATTEMPT THIS .PS REBUILDING TAKES FOREVER.
GOOD LUCK
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
Serial number CDB6HJ1
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
Dell Poweredge 2900 I912 SEL FULL
Best is to find a support or systems engineer on http://www.qual.ch if you are in Switzerland and for the UK you can find find a top Dell expert or systems specialist on http://qualifind.co.uk -- I just asked one (from Qualifind) and was informed you just need to install Openmanage and clear the logs from there, no need to down the server.
My Dell Poweredge 1550 won't connect to the
Is it in a 1, 3, 2 beep pattern (beep....beep, beep, beep........beep, beep)? If so, the memory is either not seated well or may be bad. Try reseating your memory. If it continues, try with one stick at a time just to see if it will boot up with a display.Thanks,--Brian
