20 Most Recent Dell Latitude D810 Notebook Questions & Answers
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Dell Latitude... | Answered on Jun 24, 2019
I would try taking the battery out and unplug it from the mains then hold the start button down for about 30 seconds then try again if no good try reseating the memory and if there is 2 sticks of memory try taking one out in turn and trying the other slot, or try starting it in safe mode (could be by continously pressing F8 on start up
Dell Latitude... | Answered on Dec 01, 2017
You should see a blue WiFi symbol on the "F2" key (a little tower with curved lines on each side). All of the blue symbols on the keys are functions that are toggled on or off by using the Function "Fn" key.
Press and hold the Function "Fn" key, and at the same time press the "F2" key and then release both.
You should see a comment box in the bottom right corner of the screen pop up telling you that the WiFi has been turned on or off.
Dell Latitude... | Answered on Mar 24, 2017
u might have to go back to the control panel under display look on your left and click on connect o a projector and choose a option on how you want to see your screen
Dell Latitude... | Answered on Sep 29, 2014
Hi Rhonda
I think the chip you are referring to is in the bios,you may be able to contact Dell and get them to issue you with a new password,alternatively you could try removing the motherboard battery, or flashing the bios. Not all motherboard batteries can be easily removed, some are soldered into place.
Some PC's/Laptops come with support discs that include a bios utility for just this sort of situation, again Dell will be able to tell you if such a facility exists for your Laptop, and you could also try looking on Ebay.
Dell Latitude... | Answered on Aug 10, 2014
It's on the motherboard, and you can't replace it. If you absolutely CANNOT remember (or get) that password, then you have to replace the motherboard or the whole notebook.
If they are the correct drivers and the wifi board works, it is automatic as windows loads.
Dell Latitude... | Answered on Jul 28, 2014
It's usually one of two things: Bad charging cable, or bad connection to the motherboard.
If the charging cable has a light that's lit on it, it's not the charger.
If the charger plug is loose when you plug it into the laptop, it means that the connector needs to be soldered back on. If you are unfamiliar with soldering, it's better to pay to have someone else do it, as you could easily ruin the laptop by trying to DIY. Go to your closest repair shop and have it done, most will do it for under 50.
Dell Latitude... | Answered on Jul 22, 2014
Clean the radiator before it cooks itself.
Dell Latitude... | Answered on Mar 15, 2014
We need more information.
Dell Latitude... | Answered on Jan 18, 2014
You need to have a Dell "restore" or "reinstallation" CD/DVD that match with your laptop's operating system's key number (it is located on the bottom of your laptop). If you don't have it anymore, then as far as I know, you can use a Dell Windows XP Pro DVD/CD to reinstall the operating system. Later, you need to use other computer to download some necessary drivers; copy them to your D810 notebook and install them. I have this kind of DVD, so please let me know if you need it.
Dell Latitude... | Answered on Dec 25, 2013
you have a motherboard problem which needs to be looked into.
Dell Latitude... | Answered on Sep 27, 2013
What seems to be the problem with the USB ports in the back of your PC? Please give a detailed information of the issue so that we can provide you with the correct troubleshooting steps or answer.
David
Dell Latitude... | Answered on Jun 12, 2013
Plug in the USB device and wait for windows to tell you it is ready to use. Then use it.
Dell Latitude... | Answered on Jun 10, 2013
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Dell Latitude... | Answered on Mar 07, 2013
this usually means the battery is not or will not charge, sometimes you can click the batt icon, or rest your curser on the icon and it will give you a status of it
Dell Latitude... | Answered on Mar 06, 2013
Dell Latitude D810 Notebook Logo
107 questions posted
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
LATITUDE Dell
  • LATITUDE Dell
Most Popular Question
flashing battery light
  • Computers & Internet
