20 Most Recent MidiLand MLi SW190 Computer Speakers Questions & Answers
0answers
My speaker is not working with my computer
if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar also you if this does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) hope this helps
1/27/2011 8:48:51 PM • MidiLand MLi... • Answered on Jan 27, 2011
2answers
I have this set of speakers hooked to a Dell 3000
Please check the cable using a multimeter. Check if the cable is broken.
Just by shifting the system, I fear if you could have an issue like this. Also check the Subwoofer box if its working or not. Good Luck.
6/4/2010 3:28:33 PM • MidiLand MLi... • Answered on Jun 04, 2010
Lost ac power supply adaptor for Mli 190 speakers
http://an-labs.com/multi/sw190.html 12vac
1/22/2007 5:43:12 PM • MidiLand MLi... • Answered on Jan 22, 2007
2answers
What power adapter do i need for MidiLand MLi 691H Computer Speakers??
I have no way to look that up for you.
9/24/2019 7:06:29 PM • MidiLand Audio... • Answered on Sep 24, 2019
MLI 168, are connected to
Hi
If no sound is coming from the computer, start troubleshooting your problem. Make sure both your computer and speakers are plugged in, have power, and are turned on. If the speakers are plugged in but do not appear to have any power, plug them into a different outlet. If you are using a power strip and this is case, replace the power strip. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
Once you have verified that you have power to your speakers, test the sound again. If you still do not have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8" TRS cable) is plugged into the green audio output jack on the PC.
. If you are using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you are using outlet powered speakers and have a working set handy, replace the non-working speakers with the working pair to test. If you still have nothing, let's move on to software. But one tip first: (for geeks and beginners)
If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. If you've been messing around in the BIOS, you may have disabled your on-board sound if that's what you're using. If you don't know what BIOS means, you probably haven't been there and can move on.
Go to your desktop. Click Start > Control Panel > Sounds and Audio Devices > Volume tab. If everything is grayed out, go to step 8. If the "Mute" box is checked, un-check it. In "Device Volume" make sure that your volume level is set to a comfortable volume level for your speakers.
Click the "Sounds" tab. Under "Sound Scheme" check to see if "No Sounds" is selected. If it is, click "Sound Schemes" and a drop down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. These will be indicated by a small speaker icon located next to them. Simply left click the sound once, then click the play button. If you hear sound, congratulations. If not, move on.
Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Try this fix for reinstalling drivers. Click Start > Right-click "My Computer" > select "Properties" from the drop-down menu > Click the "Hardware" tab and then click the "Device Manager" button. Device Manager will open.
Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers" If you have a red X, right click the device with the x and select "Enable" from the pop-up menu. Test your sound at this point. If you have a yellow question mark, right click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Now, click the button "Roll Back Driver" to go back to the previous drivers that were functioning correctly. Restart your computer at the prompt.
As a last resort, you can uninstall and reinstall the device. Right click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If after doing all of the steps, listed here and you still cannot hear any sound from your computer speakers, contact a qualified computer technician.
Also check the bellow link to troubleshoot your problem:-
http://www.ehow.com/how_2225072_no-sound-problem-computer-speakers.html
Please get back to us if you have further query else please accept the suggestion.
3/23/2011 5:51:11 PM • MidiLand Audio... • Answered on Mar 23, 2011
I cannot locate AC adapter for speakers MIL 699 remote speakers
I found the AC adapter for the speakers 120 Volts AC in and output 7volts 500Ma
12/16/2009 4:46:08 PM • MidiLand Audio... • Answered on Dec 16, 2009
0answers
MLi 467 Computer Speakers - where can I get
Usually people would say Best Buy, but they don't sell everything. For all my computer needs, (moniters, hard drives, CD's, speakers, etc.) I always go to Comp USA, they usually have everything to do with computers. And i'm a normal shopper there.
Good luck on finding them!
6/4/2009 10:56:54 PM • MidiLand Audio... • Answered on Jun 04, 2009
HI I have a PMX8 channel mixer and it suddenly stopped having sound output. It powers on but there is no sound.
Edited question for clarity and spelling. Remove all the sound input leads from the back and remake them. You also need to test that whatever is supplying the music is actually working. You can also try adding a new sound source. This is a made in China unit that is badged to the name of the seller. Videos in the link. https://www.google.com/search?q=pmx8+channel+mixer+no+sound ..
9/20/2021 6:01:38 PM • Audio Players &... • Answered 10 hours ago
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
9/20/2021 5:07:56 AM • Audio Players &... • Answered 23 hours ago
I need a users manual
Yes
9/19/2021 9:52:38 PM • Audio Players &... • Answered Yesterday
Need instruction manual Model Rp 50128?
Try google. Here it is; https://voxxintl.zendesk.com/hc/en-us/articles/225292647-Operating-the-RCA-RP5012-Digital-Voice-Recorder
9/19/2021 4:03:23 PM • Audio Players &... • Answered Yesterday
I need Instructions for Hifisonic Digital Clock
DrewProducer. This is a June 2012 post that has attracted spam and brought it back to the top of the pile. The spam has been removed. The OP is long since gone! Always check posting date.
9/17/2021 2:13:59 AM • Audio Players &... • Answered on Sep 17, 2021
ONKYO, HT-500 RECIEVER A Speakers work nothing else.
You would have to get it set up to be able to play with the surround speakers and be able to play with surrounded sound as well.
9/16/2021 8:19:22 AM • Audio Players &... • Answered on Sep 16, 2021
2answers
Cant find downloaded music
the songs may not be the proper format for your media player. try downloading media converter. there are many free ones online that you can find and once you convert the files try putting them back onto your media player. hopes this helps!!
9/16/2021 5:38:43 AM • Audio Players &... • Answered on Sep 16, 2021
Nuance n 200 connection to amplifier
that was a hard one, a not related to PCs topic about home audio sound music systems.(not told all parts) and super rare only found in canada and wow super freaky old, 2006? but yah speaker RCA jack goes to AMP/av/receiver/etc any made on earth, with RCA jack pre-amp out (coax cables) if one side fails the amp deep inside that speaker is blown out, and is common) the 1974 maker is now defunct, google hits = zero.
9/15/2021 12:50:48 PM • Audio Players &... • Answered on Sep 15, 2021
MidiLand MLi SW190 Computer Speakers Logo
6 questions posted
Top MidiLand Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • MidiLand Audio Players & Recorders
Most Popular Question
lost ac power supply adaptor mli 190
  • Audio Players & Recorders
