20 Most Recent Dell RADEON X600, (128 MB) Graphic Card Questions & Answers
According to this you can't.
X600 Specs:
http://ati.amd.com/products/mobilityradeonx600/specs.html
COD4 System Requirements
Recommended requirements:
CPU: 2.4 GHz Dual Core or better
RAM: 1GB for XP and 2GB for Vista
HD: 8GB Free Space
GFX: 3.0 Shader Support, Nvidia Geforce 7800, ATI Radeon X1800 or better.
Minimum requirements:
CPU: Intel® Pentium® 4 2.4 GHz, AMD® Athlon™ 64 2800+ processor
or any 1.8Ghz Dual Core Processor or better.
RAM: 512MB RAM (768MB for Windows Vista)
HD: 8GB Free SPace
GFX: NVIDIA® Geforce™ 6600, ATI® Radeon® 9800Pro or better
Dell RADEON... | Answered on Jul 07, 2009
The graphics adapter you have installed is a low end adapter and the 128MB is shared so it is very limited in its performance. You need to upgrade the adapter as this is a built in and you cannot add video memory. Hope this helps.
Dell RADEON... | Answered on Mar 29, 2009
Hi and welcome to FixYa,
Either as mshockey89 posted or try:
  • right click on any clear are of your desktop;
  • click on "Properties";
  • click on the "Settings" tab;
  • your Video card should be under Display: Plug and Play Monitor on "your video card"; or
  • click on "Advanced" button;
  • click on "Adapter" tab;
  • Video card would be under "Adapter Information".
  • if no specific brand/model is listed on either of the above, then the drivers were not installed and as mshockey89 posted, information on the "computer or motherboard model" would be needed.
Good luck and Thank you for using FixYa.
Dell RADEON... | Answered on Jan 04, 2009
Hmmm. The blue screen isnt a good think. Even though people say what kind of model a dell computer is, doesnt describe the processor, memmory modules...how much...speed etc.
You need to uninstall your graphics drivers.
Download ccleaner and drivercleaner. Do a scan with both. Do a full driver clean with driver cleaner because it clears the junk out of your registry. Make sure you do a reg backup with both programs.
Now you can restart your computer and install the latest drivers.
the x600 card is a little on the outdated side and can probly run the game on low to medium. Start with 800x600 resolution and turn aniostropic and antiliasing off. Turn everything off that you think is necessary, start the game, and see how it runs. Download fraps so you can see your fps. If you get about 60 than you can turn a setting up. If you get 30 or lower, turn your settings down.
I hope this helps. Please contact me if you need any further advies. I also want to say that you should have at least a gig of memroy and hopefully 2 gigs to play the game at good settings.
Dell RADEON... | Answered on Nov 26, 2008
No sound for where ? are you using HDMI ?
Dell Radeon... | Answered on Sep 28, 2014
the answer would be the same as.
I dropped my PC to the concrete, , how many pieces did not break.
same answer (only GOD knows that).....
the answer can be :
1: yes, if lucky, if the motor spins and can hear it , does it?
2: no if motor silent. Impossible unless pay $1000's bucks recovery services (google that. "clean room HDD recovery services")
3: yes and no, some files can be recovered,
ever seen a record player turn table,?
Imagine deep scratches, killing one song or 3, or?>
but the other tracks still play on the phonoGraph.
same deal here. but tracks are called cylinders here.
but if the heads are dead, NO,
first:
what you do is listen the drive , if the motor inside, is dead, it' s a dead HDD.(RIP)
if not, then move the HDD to other PC as second drive.
and copy your files, that way.
if possible it will work. (luck happens, fate, entropy ,etc)
Dell Computers &... | Answered Yesterday
Larry Ng is our computer guru. His advice is priceless and encyclopedic. His answer should be down here, so the answer is searchable.
Larry writes
What PC what DELL PC is this, must I guess?
Google dead today, hint 1 you are not the first nor last.
2000-0334 , it you failed to type the whole error
not even told laptop or desktop or just what model PC, (vast exist)
1000-0334 or this?
a video card GPU error of some kind
reload the Dell card driver from dell.com
or is the iGPU failing, in the CPU.
for same reason bad drivers.
if you installed W10 and dell.com told you not to do that , bingo, for no w10 drivers at dell for 10 year old PC or older, , NO PC told no OS told so there is no CLEAR answer,. ALL I can do is beg and pump,, endless
Dell Computers &... | Answered 3 days ago
What color(s) is (are) the blinking light? Is the blink a simple on/off or is there a pattern to the blinks (long/short)? Do any other lights come on and blink? (These could be on the keyboard or the battery health indicator LED.)
If the light that is blinking amber or orange indicates that the system has failed the Power On Self-Test (POST). If the blinking light is white, the system is in sleep mode. Try disconnecting the power adapter. Take out the battery and remove all external peripherals. Press and hold the power button for 20-30 seconds to discharge the system's capacitors. Try to restart the machine with only the battery and AC adapter. Did the behavior change?
You can remove memory and the hard drive to check if those are causing a POST failure. Reinstall one memory stick at a time if you have a pair or more. If you can get to the Dell splash screen, try pressing F12 to launch the diagnostics. (You may have to press the key repeatedly starting from a cold boot.)
If the blinking light is alternating orange and white, then you could have a problem with the motherboard, battery or AC charging system. Since you believe that the battery and adapter are OK, then the problem would likely be the motherboard has been damaged. The damage could be at the connection for the charger or somewhere else.
I hope this helps.
Dell Computers &... | Answered on Aug 06, 2020
SOME OF THEM WILL NEVER WORK IF THEY ARE OLDER MODELS
Dell Computers &... | Answered on Aug 05, 2020
To reset Windows 7 password with Spower Windows Password Reset, just follow the steps below:
Step 1: Download Spower Windows Password Reset Professional (trial version) and install it in an accessible windows. Spower Windows Password Reset Professional can be installed in windows 2000/xp/2003/vista/7/8/10/2008/2012/2016.
Step 2: Create a Windows password reset disk. You can use Spower Windows Password Reset to create a bootable CD/DVD or USB disk.
Step 3: Set the locked computer to boot from CD/DVD or USB drive.
Step 4: Boot the locked computer from Windows password reset disk.
Plug in Windows password reset disk to the locked computer, and restart it. Wait for a few seconds, Spower Windows Password reset program will start and ready for you.
Step 5: Reset forgotten Windows 7 password with Spower Windows password reset program.
When the Spower Windows password reset program is ready, do the steps below to reset windows 7 admin password:
Dell Computers &... | Answered on Jul 08, 2020
this is problem with overheating of motherboard. Please refer to the link. https://www.dell.com/community/Laptops-General-Read-Only/Error-code-M1004/td-p/3006198
Dell Computers &... | Answered on Jun 30, 2020
Start by pressing the menu button, select System, select Admin Menu, select Network, Select Wireless Setup, select your network from the list, then enter your network passphrase. Print a Settings Report to confirm the printer has successfully joined your wireless network.
Press Ctrl-P while booting up
Management Engine will open
use 'admin' as the password
you are required to set up a new p/w, do it.
It will prompt and say if you do it will reset, that's what is required!
then exit,
once it restarts, the error message disappears!! now you can install OS as usual
Dell Computers &... | Answered on Jun 28, 2020
You will get advice on how to format the hard drive and start again but there is no solution to lost passwords for security reasons.
Dell Computers &... | Answered on Jun 20, 2020
You can use Kernel for Outlook PST Repair Tool to repair your damaged Outlook pst file successfully. Go to http://www.pstfix.com
to download the tool and refer to http://www.pst.msoutlookrepair.com
to know more about the pst recovery.
Dell Computers &... | Answered on Jun 18, 2020
You will need to go to customer care it will be great if your device still has warranty.
Dell Computers &... | Answered on Jun 12, 2020
Computers & Internet Logo
5 questions posted
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
Radeon Dell
  • Radeon Dell
Most Popular Question
hey hp zd8000 netbook ati
  • Computers & Internet
