20 Most Recent Konica Minolta BizHub C650 Copier Questions & Answers
P21 & P8 are errors of yellow drum cartridge, replace yellow cartridge.
Konica Minolta... | Answered on May 31, 2019
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Oct 12, 2018
replace the cyan image unit
Konica Minolta... | Answered on Mar 11, 2018
was this third party??? if so replace the image with Konicaminolta unit
mam
Check the paper trays 3 and 4. jam paper behind the trays????
Konica Minolta... | Answered on May 07, 2017
check the paper trays 3 and 4. jam paper behind the trays????
The fusing unit is located on the right side of the machine, open the right side door, not the duplex door the bigger one. you will see a shinny belt do not touch as that puts the image on the paper. The fuser unit is right above it. It can be hot so power off to remove it. your code is for the fuser did you try to reset it??
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Make sure that you changed the right one. Most of the machines have two blacks.
Konica Minolta... | Answered on Aug 28, 2016
Pull out thre black image unit NOT the toner. And shake the image unit along its axis you want the developer inside the image unit to be spead along the the whole axis of the image unit not sitting at one end so the motor can not turn!!!! If that does not fix it you blew out the motor worse case you blew out the motor and the motor control board $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$.
NEVER STORE IMAGE UNIT VERTICALLY lay Flat!!!!!.
Some one I bet pick up one that was standing threw it in the machine GOOD BYE MOTOR GOOD BYE Control Board!!!!!!!!!!!!!!!!!!!!!!! $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Konica Minolta... | Answered on Jul 02, 2016
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
Konica Minolta... | Answered on Apr 29, 2016
was it replaced???????????????????
Konica Minolta... | Answered on Jan 15, 2016
This going to take a while, open both front doors do not pull out the lower section your going to pull out the upper middle section. then from the right side (WHAT EVER YOU DO NOT LEAN / HOLD ANY ONE OF THOSE FOUR SHAFTS!!!!!!!!!!!!!!! THAT WILL CAUSE MAJOR TROUBLE!!!!!!!!!!! ) Now reach in and you will see a small assy. which is across from the transfer belt on the other side of the unit you just pulled out. On the assy. are three sensors each covered bye a metal cover with a dry rag ensure no static electric can destroy the sensors. clean all three, be careful each has a small spring do not let them fall inside the machine. If you want to or have to remove that assy. there are two screws and once connector all the way in the back (DO NOT LEAN ON THOSE SHAFTS!!!!!!!!!!!) dont let the screws drop!. Once done remove the transfer belt, and clean the transfer belt cleaning blade system, then run gamma, and color checks in 36 mode. GOT IT! Better have a tech come out.
Konica Minolta... | Answered on Jan 10, 2016
run the registration procedure. do you have any oil can showing on the bottom of the control panel P-21. P-28 etc
Konica Minolta... | Answered on Dec 30, 2015
Replace the fusing UNIT.
TO Reset follow this procedure: IF the code comes BACK DO NOT RESET AGAIN DEALING WITH THE FUSER IT CAN CATCH ON FIRE!!!! That will ruin a perfectly good day!!!
Procedure:
For parts try this site for starters
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Konica Minolta... | Answered on Dec 26, 2015
what is hanging???????????????????????
Konica Minolta... | Answered on May 30, 2015
I am unable to fix the problem C225B in Konica C450 please help me i have replaced all the tonner unit and Developer kit also.
Konica Minolta... | Answered on Aug 26, 2014
what solution for the trouble code c-3B04 for c650
Konica Minolta... | Answered on Mar 26, 2014
Konica Minolta BizHub C650 Copier Logo
27 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
copier print yellow color p21 p8 show
  • Office Equipment & Supplies
