20 Most Recent Konica Minolta Bizhub C652 Color&b/w Copier/printer/scanner/fax Network,finisher Questions & Answers
What is the service code being displayed????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 18, 2018
no such code for that machine
Konica Minolta... | Answered on May 14, 2017
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Konica Minolta... | Answered on Feb 19, 2014
The Printer Is In An Error State also appear in more wrong with the all inappropriate printer driver and also need to renew the driver to retaliate problems of this kind. You can handle the best way and deal with the drivers is easier. Then, the driver is easy and more intuitive to recognize with your system and find out the all correct drives. You can access to need about the specific system your computer is running.
Reasons that cause Printer Is In An Error State:-
1. Perhaps the drivers are not installed correctly.
2. Indicate if you have downloaded the drivers and software relating to your printer model.
3. Attachment issues can also be the root of this printer error state issue.
4. BIOSS issue is a very simple factor in giving rise to this daunting issue.
5. Perhaps the wires or USB wires are not attached well.
Just follow the steps which are mention on the blog to fix the Printer Is In An Error State. We give online help for Any problem in printers our Call us on TOLL-FREE NUMBER in our BLOG.
Konica Minolta... | Answered on May 29, 2020
https://www.manualslib.com/manual/837626/Konica-Minolta-Bizhub-162.html?page=174
Konica Minolta... | Answered on May 05, 2020
Check the very bright light under the the big glass. does it come on if you make a copy. Not a print
Konica Minolta... | Answered on May 04, 2020
replace the black image unit drum
sir what model machine is it
what model machine?
Expose lamp failure. The big lite under the the big glass is out
Socket error. Check the network connection. Make sure you updated your password and email address via the copier web page. also en etc.sure the copier is using the correcting mail server gmail, office365
try this site
Using the most current print drivers. Try this site
Clear the counters first then Replace the drum and developer run the required function codes should be good to go
Konica Minolta Bizhub C652 Color&b/w Copier/printer/scanner/fax Network,finisher Logo
14 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
bizhub c652 service codes
  • Office Equipment & Supplies
