20 Most Recent Konica Minolta Bizhub C452 Copier Questions & Answers
2answers
Konica Minolta bizhub c452 makes clicking / ticking noise. also has color streaking.
The ticking noise your hearing is VERY common on the C452, C552 & C652 models. Normally it is accompanied by a slight squeak that will get worse as well. There are numerous articles that cover this but the ticking is either coming from the fuser drive assembly (just inside the right hand door on the right below the exit drive assembly) or the exit drive assembly itself. If your mechanically inclined the problem can be found with one of the gears being worn on the shaft it turns on and becoming oblong. You will need to contact a service tech or dealer for parts since you can only get them from Konica. I hope this helps!
7/11/2017 6:07:43 PM • Konica Minolta... • Answered on Jul 11, 2017
My konico minolta bizhub c452 has power failure. if i power it on, it will come up . if i off it and i power it will not come up. please i want you to help out Inbox x
check the power filters and or power supply board have tech come out. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/11/2017 8:12:02 PM • Konica Minolta... • Answered on Mar 11, 2017
How do I enter into calibration mode in bizhub c452
Please try this youtube link Bizhub Easy Color Adjustment
8/15/2016 7:31:57 AM • Konica Minolta... • Answered on Aug 15, 2016
Error Code C-B302
NVRAM has crashed need to get tech out to re=flask copier os, via secure web site. or the NVRAM and or board are bad Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/5/2016 1:54:20 AM • Konica Minolta... • Answered on Jul 05, 2016
Original left glass
where the document feeder attaches to the copier is small switch that sure pop up when the document feeder is raised and should depress when lower check it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/17/2016 4:16:27 AM • Konica Minolta... • Answered on Jun 17, 2016
Blue toner streaks
replace the cyan image unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/14/2016 10:25:31 PM • Konica Minolta... • Answered on May 14, 2016
How to remove error c-3B02
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. Either of two parts bad the High Current Assemble or the Fuser GET A TECH OUT TO LOOK AT IT. Procedure: 1. Turn OFF the main power switch. 2. Turn main power switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and it has been reset. 5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/20/2016 8:15:34 PM • Konica Minolta... • Answered on Mar 20, 2016
How to remove error c2257
DEEPAK, YOU NEED TOMORROW TO CALL MINOLTA CUSTOMER SUPPORT FOR PROPER WAY TO CLEAR THESE CODES!THAMKS
1/24/2016 5:43:07 PM • Konica Minolta... • Answered on Jan 24, 2016
Error code c-3b02
The Fuser Magnetic High Current Assy. is bad not the fuser but the section it plugs into. located below the control panel behind a cover. have a tech come out. Try this one time if the code comes back do above do above if do it again the fuser can catch on fire that will ruin a perfectly good day 1. Turn OFF the main power switch. 2. Turn main power switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and the it has been reset. 5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/18/2016 11:34:07 PM • Konica Minolta... • Answered on Jan 18, 2016
P-21 p-28
Remove the transfer bekt and clean the two sensor located below the belt in the machine, need also how to acurate the senor cover to that you clean the sensor, recommend a tech do this be careful static electricty can destroy the sensors P21 P28 deal with registration of colors on top of each other, the sensor monitor that 28 is a sensor fault and 21 that registration failed. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/18/2016 5:11:20 AM • Konica Minolta... • Answered on Jan 18, 2016
Bizhub c452 keeps turning off
have tech come out and look at it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/10/2016 11:07:33 PM • Konica Minolta... • Answered on Jan 10, 2016
MINOLTA C452 KEEPS TURNING ITSELF OFF
what is display on the screen prior to turning off Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/10/2016 6:25:15 AM • Konica Minolta... • Answered on Jan 10, 2016
C452 water toner
replace the waste toner box lower section below toner section is in front of the image units Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/29/2015 11:35:08 PM • Konica Minolta... • Answered on Dec 29, 2015
Solution for c-2656 konica minolta
Replace the Yellow image unit with OEM!! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/28/2015 10:48:32 PM • Konica Minolta... • Answered on Dec 28, 2015
Hot to fix the error c 2257
Cleaning motor failure I first remove the waste toner box and transfer belt and ensure both have clean and operating toner gears systems You might have some hard toner stuck in the aggruor system that the cleaning motor (M38) runs, hopefully it did not burn the motor out or worse damage the control board that controls it. If your not sure a get a tech out to look at it. IS the waste box properly installed? new one installed? Transfer belt new? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/27/2015 4:26:30 AM • Konica Minolta... • Answered on Dec 27, 2015
Error code c2557
The code references an abnormal low toner density in the black IU. Check the toner bottle to ensure that it is feeding toner into the sub hopper unit under the bottle. Sometimes users will insert the bottle incorrectly and not lock it properly in place...the lever on the front of the toner hopper for that bottle is moved down to the left to remove and insert the bottle. When moved to the upper position, it both locks the bottle in place and opens a cover on the bottom of the bottle. It is possible the toner hopper itself is not functioning as well. Either the motor drive is not working, that is, broken, or there is a problem with the printer control board that it is connected to. This is a rare problem and not very likely. Also, it is possible the image unit itself is defective...the sensor could be at fault...or its not pushed in correctly to make an electrical connection.
7/18/2015 5:56:44 PM • Konica Minolta... • Answered on Jul 18, 2015
Error code C3B02
Turn off the machine using main power switch not the one on the control panel. But make sure the on the control panel switch is on. Now hold down the utility/counter button and turn the main power switch on hold down to you see trouble reset touch it power off WAIT TEN SECONDS power on if code comes back DO NOT RESET it means the Fuser Electro-magnetic current amp and or coil is bad reset again it may catch on fire ruining a perfectly good day!!! Get a tech out to look at it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/14/2015 11:31:01 PM • Konica Minolta... • Answered on Jun 14, 2015
How do i clear error c-2558
Black image unit developer /drum. get new ones try for staters Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/29/2015 12:21:22 AM • Konica Minolta... • Answered on May 29, 2015
Konica Minolta Bizhub C452 Copier Logo
43 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
carpediemweb
Level 1 Expert
George Mclaughlin
Ekse
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
konica minolta bizhub c452 makes
  • Office Equipment & Supplies
