20 Most Recent Sony KF-60XBR800 Questions & Answers
I would re check your steps. If you have a harness that is not hooked up, that is bad. It goes some where.
Sony KF-60XBR800 | Answered on May 10, 2012
A common point of failure in LED backlight television is one LED will fail and the power supply wont come on. Many people replace the power supply board and it wont repair the problem. You have to replace the LED light strips.
Sony Televison &... | Answered on Apr 04, 2020
Press and hold the "Setup" button, which is located in the top left corner of the remote. The light at the top of the remote should start flashing. Now, hold down the "TV" button located on the top right corner of the remote and enter the code simultaneously.
https://www.techwalla.com/articles/how-to-program-a-sanyo-universal-remote
Sony Televison &... | Answered on Apr 03, 2020
Problem is a bad capacitor on the power board. Caution if repairing yourself as capacitors in TV's hold a charge long after set is powered off and can be lethal.
When looking at your power board for a bad cap look at the top of the capacitors. A bad cap will have a noticable "bulging" on the top of it compared to others. Be sure to note polarity of capacitor (will have a "-" on one side indicating negative. To fix on/off issue simply unsoldered bad capacitor and solder in a new one with same voltage and capacitance rating being sure the new capacitor is oriented the same as the old one was before it was removed.
Sony Televison &... | Answered on Mar 31, 2020
It's something about the Burlesque dvd. I have the same problem with mine when I try and play it on my Sony blue-ray player. It's the only disc I have that it won't play. Disc is a DVD Video disc but it will no't play in the Sony player. It plays fine on other dvd players and my computer, but not on the Sony.
On the left pane, select Settings. Select Configuring the TV. Select [TV]. to pull up the settings menu on the right pane of the TV screen.
https://www.sony.com/electronics/support/articles/00175354
Sony Televison &... | Answered on Mar 30, 2020
good day if apprat after the fall, there is a huge probability of damage to the matrix itself (display) or the display backlight lamps (they are very thin and fragile to be found directly behind the matrix), which is probably why the inverter writes an error (the block that drains the ignition of these lamps), the operation to replace these lamps is a very painstaking and complex process. if I were in your place, I would leave it to the specialists from the qualified SC.
Sony Televison &... | Answered on Mar 29, 2020
Push down and pull the back cover off.
41x8bk2fedl._ac_-undefined-undefined-0.jpg 41ibq02h5gl._ac_-undefined-undefined-2.jpg
Sony Televison &... | Answered on Mar 27, 2020
https://www.revoxremotes.com/Remotes/Sony_RM-VZ320.htm
Sony Televison &... | Answered on Mar 25, 2020
When a power supply gives trouble it often means a fault elsewhere is causing an overload - an age related shift in component values can cause the current consumption of a circuit to increase yet remain functional. This sort of condition is likely to cause stress to the power supply so it slowly cooks...
Sony Televison &... | Answered on Mar 18, 2020
Sony Blu-Ray Universal Remote Codes
  • 5 Digits Universal Remote Codes For SONY BLU-RAY. 42178. 11516. 42180. 41516.
  • 4 Digits Universal Remote Codes For SONY BLU-RAY. 2014. 2020. 2484. 2113. 2226. 2251. 2273. 2257. 2171. 2108. 2065. 2162. 2244. 2309. 2355. 2407. 2406. 2329. 2313. 2306. 2305. 2296.
  • 3 Digits Universal Remote Codes For SONY BLU-RAY. 670. 671. 644. 617. 730. 768. 729. 731. 645.
Sony Televison &... | Answered on Mar 13, 2020
Unless you have access controls on the front you will need that remote. Go to www.sony.com contact customer support and the technical department for possible replacement. Check out www.ebay.com Type: make and model and scroll down the list to see if you can luck out.
check power settings for program
Sony Televison &... | Answered on Mar 11, 2020
Sony KF-60XBR800 Logo
7 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kf 60xbr800 sound but no picture
  • Televison & Video
