20 Most Recent Epson Stylus Pro 4000-PS InkJet Printer Questions & Answers
You should be able to print the settings from the printer. Press the menu button and go to the reports and print the settings. You can also load the drivers and they will search your network for any available epson printers. I have included a link to the downloads page for documentation and drivers.
Epson Stylus Pro 4000 Print Engine
Epson Stylus Pro... | Answered on Sep 08, 2015
  1. Remove the cartridge/s you have just installed and turn the printer off for 30 seconds. This resets your printer memory.
  2. Check the copper banding on each of the cartridges. This is their contact chip and what communicates with the printer. Give them each a gentle wipe with a cloth to ensure they are clean and dust free.
  3. Reinstall the cartridge to your machine.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Epson Stylus Pro... | Answered on Jun 25, 2014
I have an Epson 4000 which I started using new in Sept 2004 and my magenta is clogged too. I've gone through 2 maintenance tanks trying to clear it, (and LOTS of ink), but the magenta is still blocked. I even tried this: http://www.youtube.com/watch?v=3NR8g4qUAJc trick but it didn't seem to work. I hope you have better luck.
Epson Stylus Pro... | Answered on Dec 28, 2012
The error relates to a carriage movement error detected by the printer. This means the printer has detected too much power is required ti move the print head. Reason : All these Service Requests (Service Requests 00010004 , 00010005, 00010006, 00010007, 0001000A, 0001000F, 0001001D) are related to a Carriage movement error that is not automatically due to a Hardware fault. The reasons can be : - The carriage is lock not completely released. - The carriage lock has been partially pushed in after a paper jam or maintenance (for example). Reminder : The carriage lock must be released after unpacking the printer (see setup instructions) as follow : Points to check : In case such an error appears: - Power off the printer. - Ensure the Carriage lock is released (pulled to the left side) - Pushing down the cutter blade, slide the carriage to the left ? At the same time, please check if there is any foreign materials / dust / paper jam in the carriage path. If so, remove them. - Also, make sure that the carriage encoder (T-Fence) isn?t dirty and is correctly set and centered. Let me know how you get on with this info.
Epson Stylus Pro... | Answered on Apr 19, 2012
Try rubbing alcohol on a cotton swab.
Epson Stylus Pro... | Answered on May 27, 2011
pon el setting (modo ) balnco y negro, ke esta en las propidades ke te presenta la impresora
Epson Stylus Pro... | Answered on Feb 09, 2011
hi please contact at 9324629632 for any printer problem
Epson Stylus Pro... | Answered on Jan 17, 2011
Hey I have had my printer for 6 years and have had the same problem. I had to manually clean it and It saved me a chunck of change. I mixed equal amounts of amonia, acohol and windex in a bottle then I set my printer on replacing the blades. Once it was positioned I turned it off and removed the plastice cover over the ink tubes. With gloves I unscrewed each color from the top. The ink will run back into the tanks but dont worry. be careful not to loose the small rubber seals inside these tubes.Place a paper towel folded under the ink heads where the paper is printed on. I had a small insulin syringer that I put fluid in and I gently pushed fluid into each ink hole. I did this several times before I got the inks to flow onto the towel and I let it sit for 20 minutes or so. I then screwed all the tubes back on each color. I removed the paper towel , restarted my printer and ran a full power cleaning. Dont be concerned like I was about the ink wasted because remember your inks flowed back into the tanks when the suction was broken. You must do the power cleaning to force the air out of the chambers and you waste very little. My printer runs like a champ the first print was awesome. It takes about 45 minutes so be patient and careful.
Here is what you will need:
Paper Towels sm phillip screwdrive
Rubber Gloves small syringe
Solution /acohol-amonia-windex
A lot of Patience
001001D is a servo parameter error.
Most likely it's because you moved the carriage off the capping station and a sensor is sensing the error.
If the print head is still on the left, turn the printer off and back on. If the print head is in its normal docking position, move it to the left and turn printer off and back on.
Things you should Check:
  1. Check the basics first:Is the encoder attached and correctly routed through the optical sensor
  2. Is the encoder strip clean - if there is a splodge on it, this will result in error
  3. If you have done maintenance, check all the connections you made are good
00010004 Motor encoder check error
00010004 error relates to the encoder strip for the carriage motor (The encoder strip is like a piece of graph paper and the head has an eye that reads how many lines it passes). This is so the machine know exactly where the head is at any point
The error means that the machine is not correctly reading the encoder impulses. The encoder, eye or the circuit board may be broken even the cable could be faulty. It could be that you have done maintenance that one of the connectors has been replaced with incorrect polarity.
There is no one answer I can give you. If you need further help with this, there a good section in the service manual that gives a sequence of areas to test to pin down the fault. Get a manual from http://www.TheServiceManualShop.com
I hope this gets you going and thank you for the chance to help.
If you have any other questions, please feel free to to ask.
Randy
FixYa Support Team.
Epson Stylus Pro... | Answered on Feb 14, 2010
Hi
try using a damp lint free cloth and try cleaing the cartridge ****.
also if you go in to the printers and faxes and rt click the printer icon and goto properties you will find clean ink cartridge under maintenance.
try cleaning the ink cartridge using that
and the cartridge should work absolutely fine.
Epson Stylus Pro... | Answered on Jul 14, 2009
code 45 is lost connection:
so plug the USB cable to another USB-port on the printer and restart it with unplugging the electric cable behind. plug it in again and put the printer to "on"
- most probably then it will see the computer again
Code 45 Currently this hardware device is not connected to the computer epson-printer-error-codes-wutfveiel3ypko01ydor435x-4-0.jpg
Epson Stylus... | Answered on Jul 25, 2020
Google (Epson)(model)(manual) without parens and proceed as directed.
Epson Stylus... | Answered on Aug 25, 2019
Epson Stylus Pro 4000-PS InkJet Printer Logo
22 questions posted
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
epson 4000 manual head cleaning
  • Office Equipment & Supplies
