20 Most Recent Epson C64 InkJet Printer Questions & Answers
Hi havent used this printer in a while and set it
Remove and then replace the black ink. Make sure you remove any sealing tape that may be covering holes in the ink cartidge. While the ink cartidge is removed, you might also want to give it good shake. Finally, the cartrice may juat have been too old - they age even when in the packaging, and most have an expiry date.
11/8/2017 11:35:41 AM • Epson C64 InkJet... • Answered on Nov 08, 2017
I have an epson printer and i recently got a new computer. My printer will not print now. It goes thru all the motions and then kicks out a blank piece of paper. i have an all in one computer
Sounds like your print head is clogged. Follow the manufacturers instructions for cleaning the print-head.
2/9/2014 8:36:55 AM • Epson C64 InkJet... • Answered on Feb 09, 2014
Dont no weather i have got it plugged in rights
The Epson C64 should be straightforward with respect to plugging the machine in, since the connection is USB. The USB cable plugs into a USB port on your computer and the power cord plugs into a wall outlet.
Perhaps the trickiest thing is determining the software needed to allow the printer to work properly. The software needed is determined by your operating system, e.g. Mac OS, Windows XP, Windows 7, etc.
7/17/2011 3:38:26 PM • Epson C64 InkJet... • Answered on Jul 17, 2011
I cannot get the yellow
Try the following steps.
1) remove the ink cartride and ckeck for damages
2) remove the ink cartridge and replace it securly.
Else the ink cartridge is faulty.
4/21/2011 7:51:38 AM • Epson C64 InkJet... • Answered on Apr 21, 2011
2answers
My epson c64 only print blank pages
hello,
Check your cartridge to make sure there is Ink in them and properly aligned
3/22/2011 10:20:11 PM • Epson C64 InkJet... • Answered on Mar 22, 2011
All colours except the black
On this printer, the black colour is a separate cartridge.
It is possible that is has run out of ink or maybe is blocked in some way.
Try removing the black cartridge and hold it up to a bright light to check the ink level.
Make sure the contacts where the ink flows out are clean and not blocked with dirt.
If there is plenty of ink but it still won't print then try a new black cartridge.
Please rate my answer if you find this helpful.
Many thanks,
Chris
3/5/2011 7:46:54 PM • Epson C64 InkJet... • Answered on Mar 05, 2011
My C64 prints Black but not Colors. Even after I
Issues in color printer are many. The most common one is the non-printing of color prints. This issue might be due to corrupted or incompatible drivers in your printer. When the driver installed in a color printer is corrupted or not installed correctly it might lead to issues. So in order to solve this issue you need to install or replace the corrupted driver with a new powerful driver; or reinstall the driver since the issue might be due to wrong installation of drivers.
1/31/2011 5:46:22 AM • Epson C64 InkJet... • Answered on Jan 31, 2011
Epson c64 power light is off but paper and ink red
Probably the waste ink tank is full.Look here.
10/30/2010 8:45:18 PM • Epson C64 InkJet... • Answered on Oct 30, 2010
2answers
Ink & Paper blink red at the same time
I managed to solve the problem, thanks to this fantastic freeware tool: http://www.ssclg.com/epsone.shtml The problem has to do with the porous inkpads which are expected to overflow after a fixed number of nozzle cleaning cycles. However the problem is a software, not a hardware one. This great tool resets countes as well as ink cartridge chips. Thank you very much FixYa all the same for trying. Too bad there are some lunatics who post unrelated topics to this forum. Kind regards, PM
9/8/2010 2:56:22 AM • Epson C64 InkJet... • Answered on Sep 08, 2010
Will not print black text
tendency is that the tubes for the ink might be clogged. what you can try to do is spray it with wd40 leave it for 3 to 4 hrs then try again. make sure you put a rag in the bottom for the spills to be catched.
8/12/2010 8:34:58 PM • Epson C64 InkJet... • Answered on Aug 12, 2010
My printer keeps printing plain
Is there tape on the ink jet cartridges after changing with new?
8/3/2010 5:38:35 PM • Epson C64 InkJet... • Answered on Aug 03, 2010
Printer is not printing any black
Hi! Just a thought. Its either you dont have any black ink or may need run maintenance to start cleaning the printer head. Hope this helps and have a good one!
5/5/2010 4:10:14 PM • Epson C64 InkJet... • Answered on May 05, 2010
Says parts need replacing but they dont how do I
If the error message reads parts inside the printer are at the end of its service life, and both red lights flashing alternately while power light is off, it is an indication that the waste ink pad is full and needs to be replaced. This part is not user replaceable so you need to take in the printer for service.
4/11/2010 6:26:20 PM • Epson C64 InkJet... • Answered on Apr 11, 2010
How can I reinstall Epson C64
you can use either the installation disc that came with the printer or download the driver from the internet or manufacturer's site
make sure that the printer is compatible to the computer before you install it to the system
4/10/2010 7:21:16 PM • Epson C64 InkJet... • Answered on Apr 10, 2010
Ink and paper lights flashing alternately
-turn off printer
-disconnect from computer
-load a couple sheet of plain paper
-press & hold paper feed button while turning the printer on
-it should print a test page if it is working fine, otherwise it is bound for service
4/2/2010 6:35:47 PM • Epson C64 InkJet... • Answered on Apr 02, 2010
Light horizontal band on printing photo.Run
you might see a little banding in the low quality mode but if you see it in the high quality mode or in text then you have a clogged jet .. you can run the nozzle cleaning utility .. that will usually fix it .. sometimes you have to run it more than once .. if cleaning doesnt help then you might need a new head (expensive) ..
4/2/2010 11:35:54 AM • Epson C64 InkJet... • Answered on Apr 02, 2010
My ink light and my paper light in turns flashing
ink problem, replace your ink cartrige
3/26/2010 3:49:48 PM • Epson C64 InkJet... • Answered on Mar 26, 2010
Red Ink Light is Staying on
You need to change your ink.
If changing the ink doesn't work for you, there is always a work around.
Go to this link and download the 'SSC Service Utility'.
After installing SSC, you can reset your ink status from your pc and you should be good to go!
3/11/2010 12:15:22 PM • Epson C64 InkJet... • Answered on Mar 11, 2010
Both red lights flashing
If the lights are flashing together then this will be a carriage error, if alternately then this will be the Service Maintenance request which will require reset software such as the SSC Utility. http://www.ssclg.com/epsone.shtml
2/10/2010 8:09:35 PM • Epson C64 InkJet... • Answered on Feb 10, 2010
Epson C64 InkJet Printer Logo
69 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
says parts need replacing but dont
  • Office Equipment & Supplies
