20 Most Recent Epson AcuLaser C8500 Printer Questions & Answers
This error code is displayed when there's a temporary "data error", means transferring data from computer to Printer to make the print outs.
It could be a corrupted or interrupted print job. It's also possible that the Data cable (usb cable) is loose or not properly connected on the computer or on the printer.
Try the following Steps:
First of all, disconnect usb cable from the printer and from the computer (unplug both the ends of the cable) Leave it Off for few minutes and then print a test page or status sheet. (do this before you connect it to the printer) Verify that there's no pending print Queues in the Print Status, if so Cancel them. Now reconnect the usb cable to the computer and on the printer. You are ready to test the printer.
If there's memory installed, please reseat it. Sometimes it's important to restart your computer. So I would suggest you to restart your computer while you keep the printer off.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Epson AcuLaser... | Answered on Aug 23, 2010
EPSON AcuLaser C8500 Revision D
Troubleshooting Overview 5-19
1.1.4.4 Service-Call Error Messages
See the following tables for the detailed information on the Service-Call
Error messages.
Engine Related Service-Call Error
*1: Does not appear with this printer because the printer’s life ends earlier.
Table 1-2. Engine Related Service-Call Errors
Error Type
E
Error Code
fff Explanation FIP
E 113 Fuser Unit malfunction (No Fuser Unit) FIP-1.2
E 510 ROS motor malfunction FIP-1.16
E 511 Motor 1 malfunction FIP-1.15
E 512 P/H Motor malfunction FIP-1.14
E 513 NVRAM malfunction FIP-1.13
E 516 Duplex Unit malfunction (Communication) *
E 517 Optional single/double c*ssette malfunction *
E 520 2nd BTR malfunction (Advance) FIP-1.24
E 521 2nd BTR malfunction FIP-1.23
E 523 PCDC malfunction FIP-1.21
E 524 Toner density malfunction (Low density) FIP-1.20
E 525 Toner density malfunction (High density) FIP-1.19
E 526 ADC sensor soiled FIP-1.18
E 527 Deve home position sensor malfunction -
E 530 Environment (humidity)sensor malfunction FIP-1.27
E 531 PR Motor malfunction FIP-1.15
E 532 P/H Motor2 malfunction FIP-1.14
E 533 Thermosensor malfunction FIP-1.25
E 534 Fuser Unit malfunction (Low Temperature) FIP-1.26
E 535 Fuser Unit malfunction (Lamp) FIP-1.26
E 536 Fuser Unit malfunction (Time out) -
E 537 Fuser Unit malfunction (Overheat) FIP-1.25
E 543 Rear fan malfunction FIP-1.30
E 544 Fuser Unit fan2 malfunction -
E 545 Fuser Unit fan1 malfunction FIP-1.28
E 546 Duplex Unit motor malfunction *
E 547 Optional single/double c*ssette unit feeder
motor malfunction *
E 620 K Deve service life FIP-1.31
E 621 C Deve service life FIP-1.31
E 622 M Deve service life FIP-1.31
E 623 Y Deve service life FIP-1.31
E 624 IBT service life FIP-1.31
E 626 2nd BTR service life FIP-1.31
E 627 IBT cleaner service life FIP-1.31
E 830 Optional double c*ssette unit LC3
malfunction *
E 831 Optional single/double c*ssette unit LC2
malfunction *
E 832 MP tray malfunction (lift down) FIP-1.40
E 833 MP tray malfunction (lift up) FIP-1.39
E 998 Engine communication error FIP-1.43
Error Type
E
Error Code
fff Explanation FIP
conclusion :
check the toner if its well plugged. or correctly.
of its leaking or etc.
Epson AcuLaser... | Answered on Feb 19, 2010
soln 1. check if any dust, paper jam or other particles inside it.
Soln 2. Rest It Using Any Resetter Software Available For Free.
Soln 3. reInstall Driver Software For Ur Epson
Soln 4. Check All Cartridges Are Full Of Ink.
Epson Office... | Answered on Jan 16, 2021
If you can't print from your Epson printer because it shows a 'Printer Down' alert, then learn how to get an Offline Epson Printer Online or make any changes to your printer settings, and you'll get your printer back online and you can resume printing your documents again. If you're using an Epson offline printer, patch windows 7, or windows 10. Then you can quickly fix the offline printer issue with the built-in toggling option between offline mode so that you can get your Epson printer back online.
Epson Printer Offline Windows 10 normally applies to a printhead issue and the displayed error message will flash on the screen. The lights will begin to blink as a symbol of this Offline 10 window. Caused by any international garbage inside a printer roller or due to a paper jam in a printer and many other PC reasons.
(If you want an instant solution to this error you can check our method or contact our Printer Expert team.)
Check Mentioned blog.
Epson Office... | Answered on Jan 04, 2021
If needed, get the current driver package for your OS version from https://epson.com.jm/Support/Printers/All-In-Ones/L-Series/Epson-L380/s/SPT_C11CF43301#drivers . Do not connect the printer's USB cable to the computer until you run the installer. (Grab the full software if you want to use the scan functions.) If you connect the USB cable first, a generic printer driver will install and the scan functions will not work. You'll have to uninstall the generic driver before continuing. Note: some third-party software that was on the original install disc may not be included in the software package.
After you run the driver installation software, connect the USB cable to the computer when prompted to do so. The all-in-one should work.
I hope this helps.
(There are other sites with the driver software; one other site is: https://www.epson.co.in/c/Epson-L380/s/SPT_C11CF43504 .)
Epson Office... | Answered on Dec 24, 2020
Error Code 0x97 in Epson WF- 4630 means there is decrement in efficiency of printer. The printer may be not printing the pages as it used to print earlier. You don't need to worry anymore. You can follow either of the Solution to resolve the Error.
Solution 1:
Step 1: Download "0x97 Fix Patch:
Step 2: Click "Scan" button.
Step 3: Click :Fix" button to repair the Printer.
Solution 2:Step 1: Restart the computer. Login as an administrator user.
Step 2: Click "Start" button> "All Programs"> "Accessories"> "Tools"> "System restore".
Step 3 : Now click "Restore my machine to an earlier date"> "Next".
Step 4: Select most recent system restore date within the "tap a restoration date" Listing and click "Next".
Step 5: Click "Next" on the verification window.
Step 6: Restart your PC is required after the completion of restoration process.
Now, try to work with your printer again.
Call Epson Printer Support Team 1-800-213-8289 if the Error is not resolved or you are having any other kind of issues.
Visit: Epson Printer Support Phone Number 1 800 213 8289 Tech Support
Epson Office... | Answered on Dec 17, 2020
not 'operated', but you can issue the 'Print' command, but that only.
Epson Office... | Answered on Dec 15, 2020
It is very common to encounter Epson Printer Error State Windows 10 with any Printer, the same is the case with the Epson Printers and scanners. They also confront the error due to some reasons. These error codes indicate some specific issues with your printer. One such problem is with the Epson Printer Error State Issue, the error popups on-screen, and unable your printer from working. If you encounter such an issue, you need to ensure that the printer is turned on and connected to your system via Wi-Fi or cable. Also, check the printer's ink, and make sure the cover is not open and the paper is not jammed.
Steps to Fix Epson Printer Error State Windows 10:-
1. Check Network Connectivity
2. Install Proper Printer Software
3. Connect the printer that requires troubleshooting
4. Full blog with a guide on how to fix Epson Printer Error State Windows 10
Epson Printer Error State Windows 10 is not resolved, this might mean there's waste within the printer's inside. Call the customer services or check this blog for a full solution.
Epson Office... | Answered on Dec 14, 2020
Epson AcuLaser C8500 Printer Logo
6 questions posted
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
problem epson aculaser c8500
  • Office Equipment & Supplies
