20 Most Recent Epson laser Printer EPL-6200L Laser Questions & Answers
Hello
Buy a smart chip resetter. It is available online for about $10.
Wipe clean the Epson cartridge using a paper towel. Pay special attention to the area where you attach the chip-resetter. Gently clean the copper nodes at the back end.
Clip the Epson chip resetter to the cartridge's back. Make sure the resetter's end with the button comes on the top.
Press the button on the top of the resetter and hold it for 5 to 10 seconds. This activity will restore the default OEM settings of the cartridge. The tiny LED light on some chip resetter models also indicate that the smart chip has been reset. The printer then recognizes the cartridge as full.
Remove the chip setter from the cartridge by pressing the release clip on the resetter's bottom.
Epson laser... • Answered on Sep 21, 2019
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved. >
a. Error light (red) b. Ready light (green)
Status/Error/Warning INDICATOR LIGHTS Ready Error Service Required (controller error) OFF > Service Required (engine error) > > Service Required (protocol error) > > Output Paper Jam > > Paper Jam > > Paper Out/Feed Jam > > No Developer Cartridge Installed > > Wrong Developer Cartridge Installed > > Installed Developer Cartridge is Not a Genuine EPSON Product > > Developer Cartridge Memory Error > > Toner Out > > Front Cover Open > > Output Cover Open > > Printing on Incorrect Paper Size > > Unsupported Paper Size > > Time Out Error > > Insufficient Memory to Print Current Page > > Paper Size Warning > OFF Not All Pages Are Printed > OFF Warming Up > OFF Replace Photoconductor Unit > OFF Toner Low > OFF Installed Developer Cartridge is Not a Genuine EPSON Product Warning > OFF Sleep mode > OFF Ready > OFF Printing > OFF Processing Data > OFF > Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Control panel: Ready and Error lights on Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Control panel: Ready and Error lights on Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot. If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper. You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears. If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Control panel: Ready and Error lights on Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Control panel: Ready and Error lights on Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge. To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
Control panel: Ready light on, Error light flashing A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
Control panel: Ready light on, Error light flashing The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
Control panel: Ready and Error lights on The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
Control panel: Ready and Error lights on The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
Control panel: Ready light on, Error light flashing The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Control panel: Ready light on, Error light flashing The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Control panel: Ready light on, Error light flashing Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
Control panel: Ready light on, Error light flashing The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
Control panel: Ready light on The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Control panel: Ready light on This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Control panel: Ready light flashing Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual) Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions. To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Control panel: Ready light flashing (flashes at longer intervals than usual) Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
Control panel: Ready light flashing (flashes at longer intervals than usual) This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge. To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears.
Sleep mode
Control panel: Ready light on Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Control panel: Ready light on Indicates that the printer is ready to print.
Printing
Control panel: Ready light flashing Indicates that the printer is printing data.
Processing Data
Control panel: Ready light flashing Indicates that the printer is processing data.
Epson laser... • Answered on Oct 27, 2015
Sound like you have a mainboard issue. It's time to replace this old workhorse unless you can find an old one with a good mainboard for cheap. A replacement printer is cheaper than the mainboard.
Epson laser... • Answered on Aug 27, 2014
6006 High voltage circuit problem
Any of the following conditions is handled as a high voltage circuit problem:
  • The charging monitor voltage (HVC_MON) signal was detected to be out of the predetermined limits after passage of the predetermined period of time from power on.
  • The transfer voltage monitor signal (T_MON_V) or the transfer current monitor signal (T_MON_I) was detected to be out of the predetermined limits.
1 Fuser unit. Replace the fuser unit.
♦Has the error been cleared?
(Yes) Replace the fuser unit.
(No) Go to Step 2
2 Main Board Assy. Replace the Main Board Assy.
(Yes) Replace the Main Board Assy.
(No) Go to "3.4.2 Electrical Noise"
Epson laser... • Answered on Jul 13, 2011
Hola.
Para empezar perdona el mi Espanol, y algun termino tecnico sera en ingles.
Para empezar, las tonterias. Asegurate que el problema no son las controladoras. Com sabes un problema de driver puede causar una impresion blanca.
Si la impresora fue desarmada, entonces lo mas facil es un conector o un junto de saldadura (soldering joint) que sea roto.
Los juntos se chequean con el multimetro en Ohms, para veer si conducen.
Los puntos que pueden dar paginas blancas son el transfer roller, la os circuitos de alto voltaje, desde psu , la unidad laser.
Aqui tambien un manual de servicio.:Epson EPL-6200L Service Manual
Esta dividido in partes y necesitas decargar winrar para abrirlo.
Epson laser... • Answered on Feb 01, 2010
los resortes van debajo de la bandeja de papel. Se colocan desde abajo, entre la bandeja y el plástico negro.
pretty sure it's dampness in the paper, because a freshly bought **** works fine. (although strangely the old paper worked perfectly in a different machine! maybe some are more sensitive than others)
Epson laser... • Answered on Oct 29, 2009
go to Epson web site (download/support) download the driver that is compatible with your operating system. www.epson.com
Epson laser... • Answered on Jun 23, 2009
plz check the manufacture website for the drivers
Epson laser... • Answered on Jun 22, 2009
there is a printer options at control panel, try to see if the setting is printing immediately,...
Epson laser... • Answered on Jun 17, 2009
Check with the cartridges. If you are using recycled cartridges it has these kind of problems. Try aligning your printer from the software. If you have new cartridges than also you can try aligning and in troubleshoot option it could be 'recalibrating/recalibration' use this option. And the best would be use software assistance and try to uninstall and reinstall the printer.
Epson laser... • Answered on Mar 16, 2009
when i am printing a small dots black appear.. what is the problem? photoconductor unit? were can i buy one here in the philippines?
Epson laser... • Answered on Mar 12, 2009
You will either need the cd that came with the printer or you'll need to download the software/drivers at www.epson.com. You can click on the support link, lookup your printer model # and then download the files that are made for the operating system you are running. Place the cd in your drive, or open the downloads and follow the onscreen instructions. Once you have done this your printer will be ready for use. Hope this helps & please take a moment to rate this solution. Thanks.
Epson laser... • Answered on Mar 11, 2009
Epson laser Printer EPL-6200L Laser Logo
Popular Tags
28 questions posted
Top Epson Office Equipment & Supplies Experts
Falling star
Kyocera HP Expert
Kyocera HP Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
using printer another pc dell
  • Office Equipment & Supplies
