20 Most Recent
Epson Stylus C20SX InkJet Printer Questions & Answers
Housing removal
If your printer is leaking ink it is most likely that the ink pads are full because the machine has been reset without replacing them.
You should contact The Service Manual Shop and get a rescue kit for machine. This will include a service manual to help you pull the machine apart and also has details of how to clean the pads and reset the counter.
http://www.TheServiceManualShop.com
No driver
Hi
Don't worry you can get drivers from www.driversguide.com
Please try to give me rating.
Driver no
it could be ur epson is not compatible with ur windows operating system that u are using check ur manual
Printer driver
Click Here to download the drivers for you epson stylus c20sx inkjet printer.
Please let me know if you have any further questions or concerns.
Thanks.
I want free download printer driver epson stylus
The printer is EoL (end of life) with Epson and out of support, so there are no reliable drivers available.
There are free drivers available all over the Internet for it but I am not sure I would trust any of the sites offering them or the software they are going to try and install (they probably have spyware and malware attached). If I was you I would probably think about investing in a new printer that will work with Windows 7 and Vista.
I lost my cd
You can go to Epson website and download the latest drivers for your printer (http://www.epson.com)
How to replace a new set of ink
If ink cartridge show red light for empty ink cartridge Just press the cartridge will come at standby those cartridge is empty ; just replace it.
If not empty you want to change
Press ink button ..... don't leave until your carriage unit not come at the replacement position
First Black will come and next color will come and after pressing ink cartridge it initialized and it will be ready /
Thanks
Driver
Go to www.epson.com and download the driver for yourself
Printer Acting strangely - red led appears after 13 seconds.
If the red error light is on by itself this indicates a Fatal Error:
Fatal error indicates one of the following:
? HP sensor lever or PE sensor lever does not
move smoothly.
? HP/PE sensor is defective.
? CR motor is defective.
? PF motor is defective.
? Main board is defective.
? Printer Housing is not secured with screw on the printer mechanism.
You could try reflashing the firmware which sometimes helps to rectify this error.
Fault with printer
Hey Bobski
The Epson software should work on most versions of Windows. If you have XP or Win 2000 you should be OK.
It could be that you have tghe dodgey SSC Utility from Russia, which is not compatible with every model and I have in fact heard that it can wreck machines by writing the wrong info to the mainboard - so beware.
I looked on my usual source for these utilities but did not see your listed - you should email the folks at http://www.TheServiceManualShop.com and ask them to supply you the reset utility for windows.
They should be able to get you up and running again.
