20 Most Recent
Epson Stylus Photo 1200 InkJet Printer Questions & Answers
Epson Stylus Photo 1200 printer. No drivers to Win
Go to this link to download the Drivers and Utilities Combo Package fo Windows XP 64 bit Edition,
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=29081&prodoid=37368464&infoType=Downloads&platform=All
Epson 1200
Try cleaning and putting a small quantity of oil the shiny metal bar that the print heads slide along. Take care not to get any oil on the rubber drive belt. Any thin oil for sewing machines or bicycles will do, even WD-40 or 3-in-1 on a tissue is fine. This is probably too late for the questioner, but someone may find it useful.
Epson Stylus 1200 lights indicate carriage jam
This means that your Epson printer has come to its end of life. In short, Epson wants you to retire your printer and buy a new one. Your Epson printer may be in good shape which is often the case. But Epson has this build-in "feature" which they want you to buy a new one.
Epson 1200 Photo Printer
There is no way to remove the printhead to clean. I would not suggest you doing it as you need to have it aligned properly after cleaning. I suggest that you go to the nearest Epson service center to have it done.
Clogged print head
This is tricky. You have to purchase printer cleaning solution. This item is available in most ink supplier.
All the lights are flashing
Hi!
the matter is that Epson, apart from the chips was invented so that when the printer takes a certain amount of printed pages (about 8000 or so, in most models), suddenly stops working , the two buttons start to flash and does not walk more.
This is because the ink that they will bring to the cartridges when cleaning heads, going somewhere.These are the waste ink tanks, this is where you stay, and the printer has a meter that estimates when the tank is full and stops the printer to prevent ink overflow and cause an internal short circuit.
How do I unlock it?
To save money and the hassle of carrying it to better manage service yourself. You download the software company that provides ssc, Static Control Components, the following page:http://www.ssclg.com/epsone.shtml
and the manual for use the program is here traslated onto english
http://translate.google.com/translate?hl=es&sl=es&tl=en&u=http://www.ahorraentinta.com.es/ayuda_ssc.htm you migth choose your printer model and reset it!
Regards
Above printer set as default
Can I please get a better description of the failure.
Right now all I can infer is that you have a Epson 1200 installed and set up as your default printer.
You appear to have defined letter size is your preferred page size. On the Epson printer, but you have not defined what the failure is and to which printer the data is being sent to,
Is the HP even an issue in this problem? Please let me know what printer you are printing to and what are you expecting the printout to look like.
I'll be online for awhile so please get back to me as soon as possible.
Don
All lights flashing, probably saturated waste ink pads. how DIY?
Ok try to connect your printer to other computer running xp. Load the driver. Then load this program see link.
http://www.fixya.com/support/t1837800-step_step_use_resetter_software
You gonna use the third party software to reset the printer counter back to zero. But be sure that your waste bin could not overflow.
I think some newer model of unit with OS X can dual boot or run with Windows Xp but the first one is the sure thing.
Not printing
have you tried to replace the ink cartridge?
if ink cartridge is new yet it's not printing, try to print a test page by going to Start>Control Panel>Printers and Faxes, then right click on the printer icon with a check mark on it, select properties.. then click on "Print test page".. if it prints or loads a paper but it's blank, then it means the printer is working, it may have run out of ink..
If it doesn't print, or doesn't load a paper, most likely there's a problem with the software for the printer.. you may have to re-install the printer drivers..
Clogged Epson Stylus Photo 2200
Well you certainly covered all troubleshooting that needs to be done and if head cleaning can´t do it -> you got to open it or have it serviced.
EPSON STYLUS RX 520 HAS AN ERROR E-91
The error E-91 on an Epson Stylus RX 520 indicates a communication problem between the printer and the cartridge. Here are some steps you can try to resolve the issue:
- Turn off the printer and unplug it from the power source.
- Remove all the ink cartridges and check for any damage or leaks. Replace any damaged or leaking cartridges.
- Clean the metal contacts on the ink cartridges and inside the printer with a soft, lint-free cloth. Make sure they are completely dry before reinserting the cartridges.
- Reinstall the ink cartridges and make sure they are properly seated.
- Turn on the printer and see if the error message still appears.
If the error message persists, try resetting the printer by following these steps:
- Hold down the "Stop" and "B&W" buttons while plugging in the power cord.
- Keep holding the buttons until the printer starts to initialize.
- Release the buttons and wait for the printer to finish initializing.
- Try printing again to see if the error message is resolved.
If none of these steps work, there may be a hardware issue with the printer and it may need to be serviced by a professional technician.
