20 Most Recent Epson Perfection 4870 PRO Flatbed Scanner Questions & Answers
3answers
Scanner not scanning
Your 'transportation locks' may have been engaged. (Check lower-left-hand-corner of the inside the scanner cover and the left-back side) See the manual: http://files.support.epson.com/htmldocs/pr48ph/pr48phrf/maint_3.htm
12/28/2016 10:52:06 AM • Epson Perfection... • Answered on Dec 28, 2016
Document Type "Film" greyed out
Close Epson Scan, unplug the TPU, plug it in, turn off the scanner, turn it on, reopen Epson Scan.
4/15/2013 8:53:18 PM • Epson Perfection... • Answered on Apr 15, 2013
3answers
Epson 4870 streaking when scanning med format negs
are you using the setting for scanning b&w ?
6/19/2012 8:42:48 PM • Epson Perfection... • Answered on Jun 19, 2012
THE LOWER SCANNER IS STUCK, AND MAKES GRINDING
did you check to see if the locking mechanism is set to lock or unlock?
on the side is a lock device that can lock or unlock the scanner during shipping.
check to see if thats the problem. It towards the back on side.
thanks adi
12/16/2009 8:19:37 AM • Epson Perfection... • Answered on Dec 16, 2009
Splitting image
Are you using the epson scan software or something else? If you are using epsons software, it might be that the picture has verticl lines that the software is mistaking for different frames on your negative. Switch the software to professional mode. I go another step and use Vuescan, it's a better application in my opinion.
12/16/2008 3:19:15 PM • Epson Perfection... • Answered on Dec 16, 2008
Bliking red light.
sounds like the 'transportation lock', check the lower left hand side corner of the inside the scanner cover and the left-back side
check this out:
so far it is not a sign of changing the bulb, plus replacing the bulb may cause more, but if in case, please try this out first.
6/22/2008 12:16:25 PM • Epson Perfection... • Answered on Jun 22, 2008
Epson 4870 ccd failure
yes you can either send it to an epson certified servicer or check this site www.epson.com/loyalty and use this passcode LIZARD
4/2/2008 7:49:08 AM • Epson Perfection... • Answered on Apr 02, 2008
Scanner won't scan full frame med format neg 2.25"x2.25"
ll you do is click on the arrow next to preview, and select normal instead of thumbnails. It took me a while to figure that out as well. Also, you will want to scan the film rightside up (opposite of what they say) and flip it in photoshop. When you scan it they way they say, the film touches the scanning bed, creating rings in your photos.
12/28/2007 2:29:58 PM • Epson Perfection... • Answered on Dec 28, 2007
4870 Photo Pro
Hi FYI, A lamp Circuit board and assembly would cost around 80% of the total cost of a brand new printer. Plus labor costs.
9/18/2007 5:09:48 AM • Epson Perfection... • Answered on Sep 18, 2007
Driver for Win 1064 bit
12/20/2015 10:02:12 AM • Epson Perfection... • Answered on Dec 20, 2015
Red and green colors appear on the right-hand edge of scans
Yes I think it is time for new scanner . Hope this helps
12/19/2015 9:24:46 PM • Epson Perfection... • Answered on Dec 19, 2015
Red flashing power light
I am sure the original poster will have probably replaced the unit by now but I just had a similar problem with my Epson Perfection 2480 Photo scanner so I think it is still worth posting the solution in case other people hit this problem in the future. All I had to do was put the switch underneath the scanner to the "unlocked" position and then reboot the unit. Hey presto it burst back into life. It's annoying to see that the manual seems to suggest that the red light means the unit is "dead" !
1/28/2015 4:03:32 PM • Epson Perfection... • Answered on Jan 28, 2015
0answers
Epson Perfection 4870 PRO Flatbed Scanner Logo
Popular Tags
20 questions posted
Top Epson Office Equipment & Supplies Experts
Mehandi Husain ...
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Perfection Epson
  • Perfection Epson
Most Popular Question
document type film greyed out
  • Office Equipment & Supplies
