20 Most Recent Foxconn 915P7AC-8KS Motherboard Questions & Answers
0answers
2answers
I want to instal a
There are a couple options.
  • Check in BIOS to see if your motherboard supports IDE emulation mode. If it does turn it on and XP will install just fine.
  • Download and read about using nlite to incorporate sata drivers into an Windows XP installation disc. (You will need another working computer. Download nlite and insert the XP disc run nlite and select your CD as your windows install file location. Download generic sata drivers, intel has a bunch you can get for free. In the nlite menu to add drivers select folder option and select the folder with the drivers. Set anything else you want in nlite and burn the new XP disc. This disc will install just fine as it now has sata drivers.
Comment if you need further instruction.
4/28/2013 3:56:07 AM • Foxconn... • Answered on Apr 28, 2013
2answers
Ethernet/lan missing so i can not connect to the
Download and install the driver from the manufacturers website. Use an external hard drive or flash drive to download from internet (working computer) and install from there.
9/10/2011 8:19:29 AM • Foxconn... • Answered on Sep 10, 2011
No sound output
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
6/21/2011 7:57:32 AM • Foxconn... • Answered on Jun 21, 2011
0answers
Can not get any pci video card to work
first off make sure you using the right cards if there not compatible they wont work check your manufacturers website second try a different slot only if you have an sli board of course and if they didnt work and your not even getting your bios screen through your card then you probably have a faulty board if its not 12months old yet there is a chance it will still be under manufacturers warranty so contact them and arrange a replacement
5/22/2010 12:37:50 AM • Foxconn... • Answered on May 22, 2010
( reinstalled Windows I have no sound.
Hello
Have a visit to intels websight and dowload sound drivers and install.
If your using a sound card you will need to get the drivers from the manufacturer.
4/14/2010 12:46:49 PM • Foxconn... • Answered on Apr 14, 2010
Foxconn Utility CD for motherboard Intel 915 series p/n: 91-185-915-MB-OM W A N T E D
Hi Witalorant,
I have searched the driver for your motherboard chipset and found one similar for the one you were looking at, i copy and paste the link here for you to download it and install it to your unit.
Click the link below and see what driver you need to download when the page loaded..
INTEL 915
Hope it helps.
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
7/29/2009 5:49:20 AM • Foxconn... • Answered on Jul 29, 2009
Sound
Hi there hey can you tell me what exactly is going on i can helop but i need to know morre about (sound)
regards mike
3/1/2009 4:43:37 AM • Foxconn... • Answered on Mar 01, 2009
Ny foxconn mb doesnot connect
If your model number posted is correct, the reason your motherboard won't connect to an agp video card is because it doesn't support agp. The Foxconn 915P7AC-8KS uses PCIe for the video bus, so you would need to use a PCIe video card. (PCIe means PCI express, specifically PCIeX16 is the form factor that you would need.) Hope that this helps.
1/11/2009 8:57:52 PM • Foxconn... • Answered on Jan 11, 2009
No audio drivers for vista 32 bit OS!
better use original version
12/20/2008 1:10:26 AM • Foxconn... • Answered on Dec 20, 2008
N15141 drivers
N15141, is not a model is Australian elect, certs codes, a useless number.g41 is old intel chip set, 3.2GB max DDR memoryno model mobo told./ at all (sticker labels not told)no answers easy butfoxconnchannel.com is dead, now, 2012 it died.ended DIY support, we guess for ever, dead 10 years.drives for what OS, not told, xp,vista,w7 or w8?windows 7 sure.,. linux?drivers are a 3 way match.the MOBO and its chip sets , vast,The OEM makers, supportand the OS.all three must match, unless using USB or VIDEO cardsbut no OS told at all.The G41 can run w10 is some rare cases. (best CPU there)2010 or newer PCs or mobo are best not old.G41 is a 2008 chip.the VGA chip there is unknown not telling real mobo model,nor if using a GPU card, VGA.?they used many then. sorry can not guess mobo models me.
5/13/2022 12:52:42 PM • Foxconn... • Answered on May 13, 2022
Foxconn n15235 front panel jumpers
n15235 is not a model number everthat is an Australian, electrical safety compliance code. and 100% useless .foxconnchannel went dead 2012. they stopped dead DIY mobo sales, and the wiki said so too.the manuals are all lost now./ but googling finds some. but no model told, no JOY.lost the CD too , new in the box it had one, with PDF on CDlost that?, yes, ouch./or get the real foxconn, model number mobothe google that and add the word manualand bingo all jumpers told. some foxconn mobo are called contract OEM mobothe top makers of OEM PC ordered those custom and put them in their PC and the only clue is the lack of any DIY foxconn model on the board at all.that n15235 is NOT IT.learn to post photos of the mobo and all labels there.
5/13/2022 11:55:54 AM • Foxconn... • Answered on May 13, 2022
Foxconn 6100K8MA/6100M2MA/6150K8MA/6150K8MD Series
ask a question? who,what ,where,why, how,, etc
5/13/2022 11:52:56 AM • Foxconn... • Answered on May 13, 2022
Pc h57m01a1-1.1-8eks3h
some boards are out of OEM PCs like gateways or the like others were sold as DIY from foxconn direct sales. did you lose the PC case? or buy just a mobo , raw? front panel pinouts you meant but failed to say just what:? foxconn (channel) went dead. 2012 the maunuls where there, then, and now all gone. they are gone. all is gone but the echo, (waybackmachine) old Intel P55 / H57 chipset age ,2009, and lost manuals, are are not, lost 2012 year when the went dead. no can find, me....
5/13/2022 11:50:16 AM • Foxconn... • Answered on May 13, 2022
Foxconn 2ABF Motherboard
you forgot the question1: need the manual ,a1, GOOGLE FOR IT2: NEED DRIVERS. WELL MAKER TOOK DOWN THERE DIY SITE.3: OR ?????????????their web site was taken down for all legacy DIY mobo .the exited the DIY businesstry buying only Asus.com mobo and only 2010 and newerTHE MOBO IS GOODIT IS Intel H61 BASED, I3 GEN2 UP, EVEN I7-2XXXRealtek ALC656 – High DefinitionHERE IS RETRO SITEhttps://theretroweb.com/hardware/motherboards/hp-foxconn-cupertino2W10 RUN ON THIS MOBO, SOUND MIGHT FAIL BUT IS EASY FIX. ASK
1/11/2022 3:11:39 PM • Foxconn... • Answered on Jan 11, 2022
Manual
is that not out of and HP.com PC? Joshua-H61-uATX (Foxconn 2ADA) sp#670960 hp says used in over 200 produces by them https://partsurfer.hp.com/Search.aspx?searchText=670960-001 step one find PC full model number not told then at HP>com click support the manual is there. see all hp service tag types here for 2 decades https://www.pcdied.com/TAG-jive/tag.html the top of your mobo has this tag https://www.pcdied.com/MoBo/hpz210.JPG and if there the SP# tells what it is. foxconn make mobo for many oEM PCs. this is a fact and the top sticker labels matter only. see more here, for foxconn (now to tell what you have) https://www.pcdied.com/foxconn.html
1/10/2022 12:34:44 PM • Foxconn... • Answered on Jan 10, 2022
Bios detection
DON'T OR SAY WHY YOU MUST? 99.9^% DON'T OR BRICK LIKE MILLIONS HAVE NOW. today is foxconn day;. and they went EOL , DYI in 2019 no PC told so is a vacuum of answers.
1/9/2022 11:41:32 PM • Foxconn... • Answered on Jan 09, 2022
Foxconn 915P7AC-8KS Motherboard Logo
17 questions posted
Top Foxconn Computers & Internet Experts
Jose Ramirez
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Foxconn Computers & Internet
Most Popular Question
download it8705f sound driver
  • Computers & Internet
