20 Most Recent Mitsubishi 3d Ready Wd-73c10 73" 1080p High Definition Flat Panel - Dlp - Tv Questions & Answers
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.
If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Mitsubishi 3d... | Answered on Nov 11, 2013
turn down volume see if you hear a noise from back where color wheel is located
Mitsubishi... | Answered on Jun 19, 2020
Is yours fitted with a fuse in the wall plug? Replace that and see if that fixes the issue. Often the checking the simple stuff first saves you a lot of money.
Mitsubishi... | Answered on Jun 12, 2020
Hello There!!!!!!
Well this is gonna take some work... First thing to start with is...
When you replace the bulb/s -does the bulb actually illuminate?
If you shine a very bright light into the surface of the screen can you see a faint image of whats on the set?
Do you get sound?
If the bulb is illuminating, is it blowing soon after?
Did the set return to normal operation after replacing the bulb the first time?
Side Note-Never touch a high power bulb glass enclosure because you can leave oils and moister that lesson the life of the bulb or make it more prone to blowing. I have no facts to support this note beside my own experiences but this is a known "thing".
Questions? Just ask. Mr.Mike
Mitsubishi... | Answered on May 20, 2020
Several problems may cause your Mitsubishi television to shut off by itself. ... Plug the television in, replace the fuse or reset the circuit breaker as needed. If the light is blinking green, a power surge or unusual digital signal was detected by the television. To prevent damage, the television shut itself off.
Mitsubishi... | Answered on May 12, 2020
Xplain issue bettr..giv som details
Mitsubishi... | Answered on Apr 30, 2020
If the status LED shows a steady yellow, that means the DMD temperature has gotten too hot. If the status LED is blinking yellow, that means the lamp cover is open. If the status LED is blinking red and then blinks yellow, that means you will need to follow that code to find the problem with the TV.
https://www.youtube.com/watch?v=INird71KKtA
Mitsubishi... | Answered on Apr 24, 2020
Sounds like main board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Mitsubishi... | Answered on Apr 19, 2020
https://www.youtube.com/watch?v=C9fiv4bI1qI
Replacing a DLP TV Chip - White Dots Issue - How to Fix...
  1. Remove DMD Board Housing Screws. [02:34]
  2. Remove DLP Chip Heatsink Screws. [03:31]
  3. Remove DMD Board Screw. [03:58]
  4. Reinstall DLP Chip Heatsink. [05:14]
  5. Reinstall DMD Board Housing. [05:37]
https://www.youtube.com/watch?v=JgiZdc4kZDw
Mitsubishi... | Answered on Apr 17, 2020
Mitsubishi 3d Ready Wd-73c10 73" 1080p High Definition Flat Panel - Dlp - Tv Logo
6 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
wd 73c10 blinking red yellow
  • Televison & Video
