20 Most Recent
Zenith Z60PV220 60-inch Plasma TV Questions & Answers
IMAGE STAYS ON FOR AN LONG TIME
Sounds possibly like image retention. If you watch the same channels often any recurring text, logos, or graphics, especially white colored, can ghost on the screen.(playing the same videogame for a long period can also have the same effect) Watching other programs or channels will cause the ghosting to disappear.To prevent image retention you need to activate the TVs anti image retention mode(Called ISM Method). On Zenith and LG (the manufacturer of Zenith T s) plasma TVs open the TVs menu, select the Option section (picture of a briefcase with a wrench). Select ISM Method and change it to Orbiter, this is reccomended if you watch programs or channels (or play videogames) that have still images for long periods of time. It moves the image a little every couple minutes. If watching others channels or programs doesn't make the image disappear, change the ISM Method to either Color Wash or White Wash (don't use White Wash frequently, it over excites the plasma gas and can shorten the life of your TV if overused) for a few minutes and then return to Orbiter.
Hook up sound bar to zenith plasma tv
If the sound bar has the red and white cable then yes you can use those. Make sure in your settings for the TV you have it set for an external audio source. Since you don't want to use the built in speakers. Probably best to get a tuner if using multiple speakers and a sub.
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
