20 Most Recent
Fujitsu LifeBook T3010D Tablet PC Questions & Answers
Fujitsu Lifebook T Series wont power on at all
1) Remove battery and power cord 2) press power button several times 3) Whack laptop on the bottom center 2 or 3 good times with the palm of your hand 4) Replace battery and plug 5) Power it up (may have to hold the power button several seconds)
My laptop is showing lock sign and not turning
That means that the computer will not boot without the proper password. If you set the password and forgot it, then you are pretty much hosed as it is nearly impossible to circumvent. Resetting the CMOS on the motherboard might help although frankly it is a very difficult thing to do on a laptop, and I cannot recommend doing it because it will most likely just get the laptop damaged. Of course if you didn't set it, just find the person that did and ask them for the password. Good luck!
Everytime i turn on my t3010d tablet pc it comes
"API failed to initialise" (sic) This means that an Application, Interface has not been able to establish a "Connection" with the base Program, it wishes to associate itself with.
Some program that is loading on startup, bootup, isn't working properly, it would most likely be best to, either stop it from starting. or reinstall the faulty program, that's failing. It may be nothing major, but the error message is a bother.
Lifebook A6220 with Vista Premium. Second user
just check are you typing the password in "capital letters".if yes make it normal then type the password again.
or try restarting it in a safe mode.by pressing f8 before the window system boots up.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Operating system not found
That error message just indicates that the syswtem tried to do a network boot and couldn't since it did not detect an Ethernet cable connected to the port.
Apparently your hard disk has died and needs to be replaced or your BIOS settings have changed and your hard disk is no longer in the boot order. Check your BIOS settings to confirm.
Fujitsu lifebook Won't start up
Please take the laptop to a repair shop for analysis. Possibly faulty motherboard or other parts. Repair price may be high.
