20 Most Recent Fujitsu LifeBook P2040 Notebook Questions & Answers
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the
most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to
reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
Fujitsu LifeBook... • Answered on Aug 08, 2014
To enter the BIOS Setup Utility do the following:
1. Turn on or restart your notebook.
2. Press the [F2] key once the Fujitsu logo appears
on the screen. This will open the main menu
of the BIOS Setup Utility with the current
settings displayed.
3. Press the [RIGHT ARROW] or [LEFT ARROW] key
to scroll through the other setup menus to review or
alter the current settings.
Go to USB Features and make sure that the USB Ports are Enabled.
Hope this Helps!
Don"t forget to rate;)
Gary
Fujitsu LifeBook... • Answered on May 18, 2011
Is this the bios password?Try this remove all power from the computer ac and battery, inside the battery bay there is a small trap door which hides a reserve battery gently pry it foward there you will see the battery unplug and wait for twenty seconds this should default the bios.
Good luck
Fujitsu LifeBook... • Answered on Jul 11, 2010
Try with VLC player or uninstall all your codecs from control panel and install k-lite codecs pack, standard is enough.
Fujitsu LifeBook... • Answered on Nov 06, 2009
hi follow this you will be set http://www.tech-faq.com/reset-bios-password.shtml good luck
Fujitsu LifeBook... • Answered on Feb 24, 2009
make sure that you have the latest drivers for your video card and audio cards turn down the visual effects of windows xp to best performance and check all background programs and see whats being used up
Fujitsu LifeBook... • Answered on Jan 05, 2009
Is there any reason for your preference for Win 2K over Win XP Pro? XP Pro would be a better choice over Win 2K.
You may be able to selecting the CD as the alternate boot device by pressing F12 as the laptop is booting up.
I am not familar with BIOS key on your laptop but you can try these keys on a cold boot up (don't use a warm boot up - Ctrl+Alt+Del keys). Try:-
Del
F1
F2
F10
Ctrl+F1 or F2
Alt+F1 or F2
Esc+F1 or F2
Once you get into the BIOS you can change the boot order, set the CD as the first device. You should be able install Windows from the CD.
If these keys don't work go to the Fujitsu WEB site to download the manual, whilst you are there you will also need to download the drivers for your model laptop the Windows version of the devices that are installed on your laptop eg. audio, video, modem, LAN etc. These need to be installed after the Windows installation.
Fujitsu LifeBook... • Answered on Dec 21, 2008
hi my suggestion is: "DO NOT MESS WITH THAT STUFF"!!! not for a lack of insufficient funds it will be smarter, cheeper, quicker and everything you can imagine to just buy a regular mouse and hook it up to the USB less then 20$ for a good 1 good luck
Fujitsu LifeBook... • Answered on Mar 26, 2006
Try a hard shutdown if the volume is up.
Fujitsu LifeBook... • Answered on May 04, 2019
your problem could be that the hard drive is broken, perhaps with some tool to repair hard disks the problem. test starting for example hiren boot from a memory or cd and see if it recognizes the hdd, if so you can pass some repair tool
Fujitsu LifeBook... • Answered on Nov 21, 2017
remove the bios password by removing the cmos battery, removing the jumper from the pins right next to the battery, marked something like pswd, plugging it in and hitting the start button.Before you open the case, unplug, remove the bettery, then hold the start button to get rid of any energy.
Fujitsu LifeBook... • Answered on May 14, 2016
please mention the laptop model
Fujitsu LifeBook... • Answered on Apr 29, 2016
Sounds like liquid may have been spilled on the keyboard. Plug in an external usb keyboard and check if it works. If so, you will need to buy a replacement keyboard and swap it out, best cheap from Ebay.
Fujitsu LifeBook... • Answered on Dec 06, 2015
Fujitsu LifeBook P2040 Notebook Logo
Popular Tags
21 questions posted
Top Fujitsu Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Carlo Barzo
Carlo Barzo
Davit Mamyan
Davit Mamyan
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
LifeBook Fujitsu
  • LifeBook Fujitsu
Most Popular Question
dell bios password
  • Computers & Internet
