20 Most Recent Samsung UN55C6300 55 LCD 1080p HDTV LED Technology Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Samsung... | Answered on Sep 23, 2015
By registering your unit w/Samsung, they will keep you current with all updates: http://www.samsung.com/us/support/owners/product/UN55C6300SFXZA
Samsung... | Answered on Nov 30, 2013
To unlock Samsung GT E3210 network lock you can use unlock code. Term Mep2 is used only for Blackberry phones. You can get the unlock code for Samsung GT-E3210 from Unlock-Zone.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Samsung GT-E3210 .
Samsung... | Answered on May 07, 2013
Check with Samsung first, most of their TVs and monitors come with a 3 year warranty and if you open the unit it will void the warranty.
Samsung... | Answered on Aug 20, 2012
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Samsung LE... | Answered on Mar 11, 2015
you will need to replace the leaky capacitors in the power supply circuit. You can locate the faulty capacitors with a visual check. Those that are bulging need to be replaced.
Samsung LE... | Answered on Mar 04, 2015
Most likely the power supply capacitors. you can identify them by their bulging tops.
Samsung LE... | Answered on Jul 24, 2014
Samsung UN55C6300 55 LCD 1080p HDTV LED Technology Logo
5 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
thin vertical lines top bottom power
  • Televison & Video
