20 Most Recent
RCA 42PA30RQ 42 Class Plasma TV - 1024 x 768, 600Hz, 10000:1 Dynamic, Questions & Answers
Rca 42pa30rq no picture with sound
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Why won't it turn on?
Fault to its main board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
My plasma TV will turn on, but there is no picture.
Wow so you've spent a lot already. I'd buy a new tv dude. It sound to me like something else has failed on a power board and they just don't replace small parts anymore you need to spend the money to replace the boards usually unless you find an old school TV technician willing to do it. It could be a the power supply so before you try anything costly see if you have a similar power rated supply around the house and see if that is the problem. Good luck. + Google the issue and you may find it to be a simple answer.!
Im wondering if the logic board may be the issue
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Why do I still have no picture on my set?
All faults might not be visual. If you have a multimeter, check the voltages at the Y-Sustain board as stated in the schematic diagram. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box.
What can be the problem with a pcb # LJ41-08592A ysus board?
have you been able to obtain a circuit diagram for the TV. because you are looking for needle in a hay stack.
You say that there is no picture , But how far does the power go to .You need to know the correct voltage at points of the TV say if its working correctly. because they only have to be out by 0.1 Volt and the devices will stop or not work correctly. Same goes for the thightristors which alter with the temperature . This is why you have been advised to get a new board.
Jeff
