20 Most Recent
Fujitsu Siemens LifeBook C1110 Notebook Questions & Answers
I will the MAC adress
go to Start/Run
type cmd and hit Enter
in the command prompt window, type getmac and hit enter
Hi
please could help me regarding
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies and
Driver
downloads
(if applicable)
as required.
The information is normally free of
charge.
I hope this helps.
How to get my wireless
There could be a switch or alt-button to push in order to turn on the WiFi. After that, search under Wifi connections and choose a network that is broadcasting in your area.
How to reset your bios on a C1110
By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it
difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS
settings along with the BIOS password. The location of this jumper
varies depending upon the motherboard brand. You should read your
motherboard manual to check its location. If you don't have the manual
then look for the jumpers near the CMOS battery. Most of the
manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and
the jumper will be joining the center pin to either left or right pin.
What you need to do, is remove the jumper and join the center pin to
the opposite pin. e.g. if the jumper joins center pin to left pin, then
remove it and join center pin to right pin. Now wait for a few seconds
and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
Do it at your own risk or under any technical guidance.
I have C1110 Lifebook. It switch on only when it
Take the battery out and only hook up the AC Adapter. Now turn it on at different times and see if the laptop turns on continuosly. If it does start turning on like normal then that means the battery is shorting out the motherboard.
Also try hooking your laptop straight to a regular wall outlet. Sometimes going thru a surge protector or UPS backup can cause strange things to happen on computers or laptops.
If you have the same problem then that means the motherboard is starting to go bad and would need to be replaced. cause thats where the power connector goes thru.
Kayboard not work 5-10%
his is mostly if you have powered somethg on those particular keys try to remove them and clean the surface then back.
Computer does not communicates with mobile network
You have to install a driver that will make it to communicate or probably install an application that will make your computer to communicate with it, else is will continue like that. what brand/model of phone do you want to connect maybe I can give you a better application to install.
Keyboard
To change it, go to the control panel, regional & language options.
