20 Most Recent Panasonic Tc-p50g20 Viera G20 Series 50" 1080p Wifi Plasma Hdtv Hdmi Questions & Answers
Well isn't this just a find how do you do!!
It appears that on this set there is no headset or other audio connection other then the optical?
It appears the only way to a traditional RCA audio jack is via a special adapter. See image. Inexpensive not sure of the quality of audio.
The best way would be to purchase a sourround sound speaker amp system with 5 speakers plus base woofer. These surround sound systems are usually have optical connected and for best results this would be my first choice.
Some have wireless back speakers to allow for easier installation.
RCA RT2781BE 1000W Home Theater System with Bluetooth This unit has two optical inputs and one digital input.
This is an inexpensive surround sound speaker system that should connect to your Panasonic TV optical output. Very available and I wanted to give you at least one option. Wires etc are a mess but the surround sound can be amazing. I would check all the reviews if you decide to go with this type of audio system. They can be confusing and in your case you need to have input control of volume with optical.
The following link is the manual for this particular Home theater System.
http://rcaav.com/wp-content/uploads/2014/11/RT2781BE_IB_0708.pdf
These audio systems can be very expensive. Less expenesive sorround can still provide great listening results.
Hope this helps?
Panasonic... | Answered on Mar 03, 2016
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Panasonic... | Answered on Dec 16, 2014
Check the capacitors on the power board. Looks for split tops with leaking stuff .
Panasonic... | Answered on Jun 24, 2014
Sounds like you have a bad input board and it is only time before you lose three. If it is under warranty get it in otherwise start tracking down the part. Most of these are a plug and play device once the tv is apart.
Panasonic... | Answered on Jun 10, 2014
My panasonic TC-P50G20 does not power on, just I have 4 blinks on my powericon1.png indicator light. What error does that mean?
Panasonic... | Answered on May 31, 2014
replace the power supply
Panasonic... | Answered on Sep 30, 2013
Remove the attaching hardware
Panasonic... | Answered Yesterday
After the TV is turned on, is the power indicator on?
If you need tv parts you can link to https://www.abctay.com to search the tv parts number.
Panasonic... | Answered on Oct 16, 2020
Disconnect the power source and allow to sit for several minutes.
Remove and reconnect the aerial or antenna connections and reconnect. Power unit on and run a New Channel search from aerial only.
Panasonic... | Answered on Sep 24, 2020
Panasonic Tc-p50g20 Viera G20 Series 50" 1080p Wifi Plasma Hdtv Hdmi Logo
19 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
attach external speakers rca plugs or
  • Televison & Video
