20 Most Recent Sanyo DP50740ARB 50 Plasma HD TV 720p Refurbished Unit 1 Each Questions & Answers
TV shut itself down and won't turn back on
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
1/21/2015 6:39:14 AM • Sanyo DP50740ARB... • Answered on Jan 21, 2015
I have a Sanyo DP50740. Had about 2 years. All of a sudden it started shutting off after turning on. Will not turn on again until unplugging and plugging back in. Then it shuts off again right away. C
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
7/18/2014 4:12:36 AM • Sanyo DP50740ARB... • Answered on Jul 18, 2014
Sanyodp50740
Follow the voltage to the power supply and then beyond, I have seen ones where every board was replaced and set still would not work=bad display panel that is shorted inside.
12/19/2012 10:04:55 PM • Sanyo DP50740ARB... • Answered on Dec 19, 2012
Both of my remotes will no longer turn on and off my Sanyo FW32D06F TV
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. https://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ https://electrohelponline.blogspot.com/ https://remotesearch.blogspot.com/ One among the posts has details about how to check a remote control. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in desktop computer or b Webview by mobile. Mobile View has no search box.
11/15/2021 6:39:37 PM • Sanyo Televison... • Answered on Nov 15, 2021
What is the av10 universal remote code for sanyo
Hi I googled your question and this site came up, The link is the av10 universal remote manual codes... Hope I helped... https://drive.google.com/file/d/0Bxy2ulXXL964WXBKWmdPakg4SmM/edit
11/10/2021 7:12:13 PM • Sanyo Televison... • Answered on Nov 10, 2021
How can I update my Sanyo Tv,It is not a smart tv
Upgrade to newest version firmware on you device, sanyo tv custom firmware update you current version firmware to latest version, download newest firmware. Download new release software and update firmware last version
  • Last update version: 02.01.2020
  • Country: All
  • Download Size: 134 MB
  • Language pack: English, Chinese
  • Version: 5.1.11
Download and update firmware for products: sanyo fwbp505f firmware update, sanyo blu ray firmware update, sanyo android tv firmware update, sanyo projector firmware update, sanyo fw55d25f firmware update.
10/29/2021 5:11:35 AM • Sanyo Televison... • Answered on Oct 29, 2021
SANYO DP58D34 flat screen tv is dead, no led
It might be the fact that our TV has died and is not working anymore and you should purchase a new TV then to fix the one that you have that has died.
9/2/2021 1:14:08 AM • Sanyo Televison... • Answered on Sep 02, 2021
Sanyo TV has bad echo. How do I fix it???
Turn surround sound or spacial sound option off.
8/28/2021 6:03:29 AM • Sanyo Televison... • Answered on Aug 28, 2021
Where's the video botton on SANYO JXPYF remote?
hy can i get sanyo remote Jxpyf
8/20/2021 1:45:18 PM • Sanyo Televison... • Answered on Aug 20, 2021
2answers
I have a Sanyo tv power y one but screen went black how can I fix it
If there is sound but the screen is black, try shining a torchlight at the corner of the screen. if you can see some images, the probable cause would be the backlighting.
8/8/2021 12:24:20 AM • Sanyo Televison... • Answered on Aug 08, 2021
2answers
I have a sanyo tv turn on but screen goes off in a few seconds
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors - Flickering screen - Screen image disappears after several seconds - Dim screen - Slow start - Power LED on, but no picture - Unusual colors and/or lines The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad. If they appear bulged on top, then they need to be replaced. New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years. Check the cables, connectors and connections. Take it to a repair shop. https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
8/1/2021 7:31:09 PM • Sanyo Televison... • Answered on Aug 01, 2021
Sanyo tv wont power on after power surge
Model?
7/31/2021 6:32:33 PM • Sanyo Televison... • Answered on Jul 31, 2021
How to get a ge universal remote to pair with a sanyo tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ https://homehol.blogspot.com/
6/27/2021 3:31:32 AM • Sanyo Televison... • Answered on Jun 27, 2021
Sanyo DP50740ARB 50 Plasma HD TV 720p Refurbished Unit 1 Each Logo
8 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
tv shut itself down turn back
  • Televison & Video
