20 Most Recent
Emerson LD195EMX 19-inch LCD HDTV/ DVD Combo Questions & Answers
My Emerson LD195EMX is flashing
Hi Jamie, welcome to fixya
I have here a procedure that works well on Sylvania tv`s , since both brands/models are made by FUNAI , it may work on yours as well.
With the tv`s original remote control and in one sequence, press the arrow left then right and power.
As i said this works with sylvania but will it work on yours ????
Nothing to loose by trying i guess :)
I`d like some feedback on this if it does.
By the way this problem is known to occur after a power blackout or if the power cord or power bar is turned off while the set is playing.
Hope this help and good luck.
I can get closed caption on many stations, but not on Hallmark and I can on a cheap TV. What can I do to get it on Hallmanr?
Good question. Set your channel on the hallmark channel. Then go to your menu to the control that turns captioning on. Turn it off, then turn it on to see if it works. If this doesn't work try to reset the entire unit. Unplug the unit, wait 2 minutes. Turn it on , go through the procedure to find channels, turn the caption control to on and see what happens. If that doesn't work I'd ask your tv service provider of contact customer service at the number listed in your users manual. Good luck. Closed captioning is required by law under the Federal Americans with Disabilities Act. Its gotta be there some where or they can't get a license to operate a station.
RED GREEN AND BLUE
hi sound like epprom fault there's a memory chip installed on the main board of the tv sometimes these can cause this fault hope i'm wrong good luck
regards
shaun
Dvd stuck inside
un plug the tv open the back by unscrewing it take the cd out and put the tv back together
Ld195emx
To set picture mode, a remote control is a must.
Tv is froze up or something
Just make a hard reset to this set and try. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset. Still the problem persists, contact any experienced service technician. The digital board should be checked.
How to setup a onn remote control to a emerson TV
1. Turn on your Emerson TV.
2. Consult the ONN remote manual for Emerson TV codes.
3. Press TV on the ONN remote.
4. Enter the correct code.
5. Test remote functions.
- If unsuccessful, try code search or auto-programming.
6. Ensure compatibility.
1/8/2024 3:58:07 PM •
Emerson...
Answered
on Jan 08, 2024
My Emerson DVD player says Disc Error Playback feature may not be available on this disc
The error message "Disc Error Playback feature may not be available on this disc" can have a few different causes. Here are some of the most common:
- The disc is not compatible with the DVD player. Some DVD players are only compatible with certain regions or formats of discs. If the disc you are trying to play is not compatible with your DVD player, you will get this error message.
- The disc is damaged. If the disc is scratched, dirty, or otherwise damaged, it may not be able to be read by the DVD player.
- The DVD player is faulty. If the DVD player is faulty, it may not be able to read discs correctly.
Here are some things you can try to fix the problem:
- Try playing the disc in another DVD player. If the disc plays in another DVD player, then the problem is with your DVD player.
- Clean the disc. Use a soft, dry cloth to clean the disc. Be careful not to scratch the disc.
- Format the disc. If the disc is formatted for a different region or format, you may need to format it for your DVD player.
- Reset the DVD player. If the DVD player is faulty, you may need to reset it.
If you have tried all of these things and you are still getting the error message, then you may need to replace the DVD player.
7/6/2023 7:52:52 PM •
Emerson...
Answered
on Jul 06, 2023
