20 Most Recent Emerson 32in Class LED-LCD 720p 60Hz LED LCD HDTV - Refurbished Questions & Answers
Why did it turn off and start chirping?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
10/14/2015 8:27:10 AM • Emerson 32in... • Answered on Oct 14, 2015
Emerson LC320EM2 no power, no sound, blows the 4
this is a combo power inverter board there are several parts to replace , one is the main transistor and check the rectifier diodes along with your brain for buying an emerson
11/3/2013 2:17:11 AM • Emerson 32in... • Answered on Nov 03, 2013
Emerson LC320EM2 HDTV
If the inverter that supplies power to LED back-lights, the screen will be dark, and sound will be OK. Check it. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
4/26/2013 5:05:13 PM • Emerson 32in... • Answered on Apr 26, 2013
Can u plug headphones into an emerson 32in hdtv
If it has an earphone jack,,,sure!
3/6/2013 4:28:56 AM • Emerson 32in... • Answered on Mar 06, 2013
Emerson problems
Look for any jammed buttons on remote or on TV control panel. Try changing the input device to something you are sure, works. Try changing the settings to factory default and see.
7/29/2012 1:36:17 PM • Emerson 32in... • Answered on Jul 29, 2012
How to setup a onn remote control to a emerson TV
1. Turn on your Emerson TV. 2. Consult the ONN remote manual for Emerson TV codes. 3. Press TV on the ONN remote. 4. Enter the correct code. 5. Test remote functions. - If unsuccessful, try code search or auto-programming. 6. Ensure compatibility.
1/8/2024 3:58:07 PM • Emerson... • Answered on Jan 08, 2024
I have a ONN remote model CR-55A1 . I want to setup it up to control my Emerson Television.
I can't find anything that says what the DR-55A1 is? Is it a Onn Universal Remote or to a specific item like a DVD or ONN Television? If it is, you can't do that, one device, one code. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
onnremotes
ONN Remote Control https://www.onnremotes.com Your ONN remote can control up to 6 devices and is remarkably easy to set up. These video tutorials will give you step-by-step instructions for programming the ... Missing: 55A1 ‎' Show results with: 55A1 ..
1/8/2024 2:15:46 AM • Emerson... • Answered on Jan 08, 2024
QR code for 55" Emerson tv model LF501EM4A
No idea what you mean and neither does Google. Why do you want a QR Code? https://www.google.com/search?q=Emerson+LF501EM4A+QR+code https://www.google.com/search?q=Emerson+LF501EM4A ..
1/2/2024 9:29:02 PM • Emerson... • Answered on Jan 02, 2024
Emerson Cks3516 SmartSet Dual-Alarm Clock Radio stopped working properly. Projection showed 8:88 am. Unplugged and replugged in. Now projection doesn't turn on. Help?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjT3Z6wx5SCAxUTrYkEHRSLDXMQFnoECBwQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft29937234-emerson_cks3516_smartset_dual_alarm&usg=AOvVaw0jD-XY5Po6uxNflfX6Ep8g&opi=89978449
10/26/2023 8:32:11 PM • Emerson... • Answered on Oct 26, 2023
How do you factory reset an Emerson tv LC320EMX without a remote??
Refer to Page 6 of user manual (Introduction). ManualsLib - Makes it easy to find manuals online! Manual switches on the side of TV can be used instead of remote control.
10/17/2023 9:15:42 AM • Emerson... • Answered on Oct 17, 2023
Emerson TV shuts off after logo, how to fix?
This is a boot log error, replace the main board and it should work.
8/24/2023 2:56:57 PM • Emerson... • Answered on Aug 24, 2023
2answers
Emerson LHD32K20US television. I need to hook up DVD player. I can't find the channel for my player?
I can't find a manual for it, but normally you don't search for 'Channels'. The DVD Player is connected via an HDMI socket in the television and you use the Source or Input Button on the Remote to find the HDMI Socket that the DVD player is connected to. They are normally number on the set HDMI 1, HDMI 2 etc., As you click through, you will see the HDMI input number flashed on the screen. https://www.google.com/search?q=emerson+lhd32k20us+manual ..
7/8/2023 6:28:43 PM • Emerson... • Answered on Jul 08, 2023
My Emerson DVD player says Disc Error Playback feature may not be available on this disc
The error message "Disc Error Playback feature may not be available on this disc" can have a few different causes. Here are some of the most common:
  • The disc is not compatible with the DVD player. Some DVD players are only compatible with certain regions or formats of discs. If the disc you are trying to play is not compatible with your DVD player, you will get this error message.
  • The disc is damaged. If the disc is scratched, dirty, or otherwise damaged, it may not be able to be read by the DVD player.
  • The DVD player is faulty. If the DVD player is faulty, it may not be able to read discs correctly.
Here are some things you can try to fix the problem:
  • Try playing the disc in another DVD player. If the disc plays in another DVD player, then the problem is with your DVD player.
  • Clean the disc. Use a soft, dry cloth to clean the disc. Be careful not to scratch the disc.
  • Format the disc. If the disc is formatted for a different region or format, you may need to format it for your DVD player.
  • Reset the DVD player. If the DVD player is faulty, you may need to reset it.
If you have tried all of these things and you are still getting the error message, then you may need to replace the DVD player.
7/6/2023 7:52:52 PM • Emerson... • Answered on Jul 06, 2023
Anyone know the start and run cap values on an Emerson LR63596 model T63XWBSS1486, labels have deteriorated
The capacitor values for the Emerson LR63596 model T63XWBSS1486 motor will depend on the specific application and the motor's specifications. Without more information about the motor's voltage, horsepower, and other details, it's difficult to give a precise answer. However, as a general rule, the capacitor values for single-phase AC motors like the Emerson LR63596 typically range from around 5-80 microfarads (µF) for the start capacitor, and 5-100 µF for the run capacitor. That being said, it's important to note that the specific capacitor values required for your motor may be different, and using the wrong values could cause damage to the motor or affect its performance. Therefore, it's recommended to consult the motor's documentation or a qualified technician to determine the correct capacitor values for your specific application.
6/27/2023 5:47:05 PM • Emerson... • Answered on Jun 27, 2023
Where are fuses on a Emerson TV model # LD190EM2
Fuses are solder in, and chances of a fuse blowing without other bad components are slim, take it in for service or better yet buy a new TV unless you have a multimeter and know how to trouble shoot a tv
6/25/2023 4:56:05 PM • Emerson... • Answered on Jun 25, 2023
Emerson LC195EM9 did channel search and all channels vanished Now do channel search and no channels registered signals have new amplified leadzm antenna with in line amplifier
1st make sure your tv is in antenna mode in settings, then take out the seperate amp run direct and try again famous with china placement of antenna is very imortant but you should get at least a couple.close channels. Now all this is providing it was working before https://irionstvshop.com
5/31/2023 12:20:30 PM • Emerson... • Answered on May 31, 2023
Emerson LTDN42V68US television will not power on. The light just blinks red continuously ..
What's happening with your TV is the backlight inverter is sensing over current and shutting the entire power supply down (excluding the standby supply) this gives the 1 blink code. Reason for over current is open circuit in the LED backlights, you will need to replace the lamps to fix the issue, there is about a 2% chance of it being a faulty power supply but in most cases it's the lamps. This is common on most Funai brand sets.
4/8/2023 3:47:08 PM • Emerson... • Answered on Apr 08, 2023
2answers
How do I connect a soundbar to my Emerson TV?
Use the headphone input on the TV.
3/12/2023 3:22:55 PM • Emerson... • Answered on Mar 12, 2023
Emerson 32in Class LED-LCD 720p 60Hz LED LCD HDTV - Refurbished Logo
12 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
turned off started chirping
  • Televison & Video
