20 Most Recent Gateway M320X Notebook Questions & Answers
Have a read.
How to Reset Forgotten Password on Gateway Laptop www.windowspasswordsrecovery.com > Resource > Password
A Gateway password is the password that you must enter to log into the administrator or user account on your Gateway laptop or ... You Forgot Gateway Laptop Password?
  • 4 Workable Ways to Recover Gateway Vista password www.windowspasswordsrecovery.com > ... > Windows Vista Password
    Lost Gateway Laptop password? ... 4 Workable Ways to Recover Gateway Vista password. ... you should login Gateway Desktop and enter User Accounts by clicking ...
  • How to Reset or recover the lost Gateway Laptop Windows ... www.windowsloginrecovery.com/reset-gateway-windows-7-password.html
    Forgot your Gateway laptop password? ... How To Get Gateway Windows 7 password reset or ... Reset Admin or other user account passwords with USB Flash ...
  • Gateway Official Site: Worldwide support.gateway.com/s/Mobile/Gateway/M320/3501937sp34.shtml
    Gateway.com Support. Select a country or region. Americas. Canada (English) Canada (Fran?ais) United States; Mexico; Argentina; Brasil; Colombia; Panama; Peru ...
  • Forgot Administrator Password for Your Gateway Computer ... www.top-password.com/knowledge/reset-gateway-password.html
    Forgot Windows login password for your Gateway computer? ... Forgot Windows 8 Password; Reset Windows 7 Password; Bypass Windows 7 Password; Windows Password ...
  • GATEWAY Bios Password, Unlock Your Laptop in minutes gateway-bios-password.biosremoval.com
    Here is the solution to unlock Gateway Bios Password, Gateway Password, Gateway user ... 2013, Gateway Bios Password, Gateway Password ... M320, M320S, M320X ...
  • How to Reset Gateway Laptop Password Windows 7 - Unlock ... www.youtube.com/watch?v=EUx5AjTCLFw
    • BY LYNDON MOSES
    • 3 MIN
    • 14K VIEWS
    • ADDED 2013-11-25
    Video embedded ยท How to Reset Gateway Laptop ... This may be the fastest way to recover a lost Windows 7 password that ... How to crack windows 7 "user login" password ...
  • Gateway M320X... | Answered on Aug 18, 2019
    hi there you only want the driver right? let me know your operating system.
    Gateway M320X... | Answered on Jan 19, 2011
    If there is no physical switch, look at the top of your keyboard. You should be looking at the "F" keys ( F!, F2, F3 etc or the number keys (1-2-3-4-5-etc) You should see a little symbol which looks kind of like this ))) (It will be 3 ('s starting small and getting progressively bigger) this is your wireless switch.....hold down the ctrl key and hit this button (Depending on the model, you might have to hold down ctrl, alt or shift) I run into this all of the time....Your manual should give you this info. If you dont have one, go to dells website and download one...it's free. Hope this helps
    Gateway M320X... | Answered on Jun 16, 2010
    To find what motherboard you need for replacement, you need to check the Part Number on a sticker on the motherboard, usually located under slot 1 of your laptops RAM ports..
    yours will be either:
    40-A07040-B400
    or
    40-A07040-B300
    or
    40-A07080-B500
    Gateway M320X... | Answered on Nov 15, 2009
    You could have a defective screen - a defective inverter or a CCFL lamp.
    To determine if you have a LCD screen or video card problem, read this and follow the instructions.
    Defective CCFL backlight, it may have the following symptom:
    • Screen flashs on red/pink and off.
    • Picture stays on in red and slowly be come normal.
    • Picture flickering with dim display or appear black.
    • Picture flickering on and off.
    All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
    Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
    Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
    The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
    Check out www.lcdparts.net for parts, repair service and DIY info.
    Gateway M320X... | Answered on May 14, 2009
    its eather got to much dust on it or something stoping it from moving
    or the fan moter has simply gone bad you can eather take it apart yourself and fix it or bring it to a shop
    but no matter what dont use the laptop till it works you will overheat the prosessor and the laptop will be useless
    Gateway M320X... | Answered on Mar 30, 2009
    it sound to be loosen connection from inside the latop..you must check the lcd cable and refix it tightly..try..i hve same problem that i fixed
    Gateway M320X... | Answered on Jan 04, 2009
    Well the best method ofcourse is to keep a backup of password in your head or maybe in a secure place. But if like me you didn't do that then ...
    Backdoor passwords
    Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations. Keep in mind that the key associated to "_" in the US keyboard corresponds to "?" in some European keyboards. Laptops typically have better BIOS security than desktop systems, and we are not aware of any backdoor passwords that will work with name brand laptops.
    WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords
    Award BIOS backdoor passwords:
    ALFAROME ALLy aLLy aLLY ALLY aPAf _award AWARD_SW AWARD?SW AWARD SW AWARD PW AWKWARD awkward BIOSTAR CONCAT CONDO Condo d8on djonet HLT J64 J256 J262 j332 j322 KDD Lkwpeter LKWPETER PINT pint SER SKY_FOX SYXZ syxz shift + syxz TTPTHA ZAAADA ZBAAACA ZJAAADC 01322222
    589589 589721 595595 598598
    AMI BIOS backdoor passwords:
    AMI AAAMMMIII BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER A.M.I. CONDO
    PHOENIX BIOS backdoor passwords:
    phoenix, PHOENIX, CMOS, BIOS
    MISC. COMMON PASSWORDS
    ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj
    OTHER BIOS PASSWORDS BY MANUFACTURER
    Manufacturer Password
    VOBIS & IBM merlin
    Dell Dell
    Biostar Biostar
    Compaq Compaq
    Enox xo11nE
    Epox central
    Freetech Posterie
    IWill iwill
    Jetway spooml
    Packard Bell bell9
    QDI QDI
    Siemens SKY_FOX
    TMC BIGO
    Toshiba Toshiba
    TOSHIBA BIOS
    Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
    IBM APTIVA BIOS
    Press both mouse buttons repeatedly during the boot
    Password cracking software
    I have listed some of the best software ways available to crack. All these will require a floppy drive access.
    # Cmos PWD <best bet>
    CmosPwd is a cmos/bios password recovery tool. CmosPwd works and compiles under Dos-Win9x, Windows NT/W2K/XP/2003, Linux, FreeBSD and NetBSD.
    [rank=www.softpedia.com/get/Security/Decrypting-Decoding/CmosPwd.shtml]More Info and download[/rank]
    # UnAward
    Hack any AWARD BIOS password in real time (6)
    [rank=www.softpedia.com/get/Security/Decrypting-Decoding/UnAward.shtml]More Info and Download[/rank]
    # RemPass
    Program can:
    - find and show BIOS password
    - collapse BIOS password
    - save BIOS settings
    - restore BIOS settings
    its just 5$ and btw free version will not reveal 3 characters.
    [rank=natan.zejn.si/rempass.html]More Info and Download[/rank]
    # KillCMOS
    If you have forgotten your CMOS password--there's no longer a need to worry! As long as you are able to boot from the floppy KILLCMOS will remove the password.
    Btw this is detected as trojan by antivirus software. However multiple sources on net say that this is untrue. Use it at your own discretion
    [rank=www.utilitygeek.com/details.php?fileid=82]More Info and Download[/rank]
    Cmos password recovery tools 3.1
    Gateway M... | Answered on May 28, 2016
    Go into Display properties, contrast and brightness.
    Gateway M... | Answered on Apr 29, 2015
    the best way is to open the laptop up take out the small battery leave it out for about ten seconds then put it back in,most of the time this will do away with passwords.
    this is called the cmos battery.
    Gateway M... | Answered on Apr 04, 2015
    XP has probably not got the SATA drivers required to find the drive. It is too old.
    Have you initialised the new hdd?
    Gateway M... | Answered on Mar 07, 2015
    Good day Jose
    If you are stuck at the computer "Locked" screen then you will have to press the Ctrl, Alt and Delete keys simultaneously to be able to type your password to unlock your screen.
    Gateway M... | Answered on Nov 20, 2014
    If you go to mrmemory.co.uk. Navigate to your laptop and compare with how much RAM you have already then you will know whether it is possible.
    Gateway M... | Answered on Oct 07, 2014
    If you are downloading from gateway's web site, disable avg.
    Gateway M... | Answered on Oct 05, 2014
    it is actually asking for a bios password
    Gateway M... | Answered on Sep 27, 2014
    The manufacturers do not supply things like this as the triple layer board is considered not repairable and a replacement item only.
    Gateway M... | Answered on Sep 16, 2014
    Gateway M320X Notebook Logo
    8 questions posted
    Top Gateway Computers & Internet Experts
    Lee Hodgson
    Lee Hodgson
    Michael Thomas
    Michael Thomas
    efs_perpends
    efs_perpends
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    M Gateway
    • M Gateway
    Most Popular Question
    lost audio driver when upgraded windows
    • Computers & Internet
