20 Most Recent
Gateway NMZ-500SE Notebook Questions & Answers
Gateway 500SE sound card driver problem
try finding the name of the sound card and then visit the realtek website to download the compatible driver k.. U can locate the name of the sound card in device manager under Unkown devices... Take care..
4/10/2010 7:29:33 PM •
Gateway...
Answered
on Apr 10, 2010
Black screen, no boot
Does the mobo have integrated graphics? If so, you may want to try installing a new graphics card and disabling the onboard. I had the same problem with an eMachines. When I installed the AGP card, it worked just fine.
2/18/2010 4:38:17 AM •
Gateway...
Answered
on Feb 18, 2010
Gateway E-Series Machine
look for any screws in the back near a side panel(usually the right side). loosen them all!
then, look for any sort of button in the back to push down on. push it down while pulling backwards on the case panel.
I hope this helps!
6/11/2009 7:45:36 PM •
Gateway...
Answered
on Jun 11, 2009
I'm trying to fix a gateway MFATXNIN NMZ 500SE
Check the adapter with a multi-meter to see if there is voltage at the plug that connects into the laptop. The oltage reading should be slightly higher than the voltage that is printed on the label on the adapter.
Try to borrow an adapter (same as yours) and connect it to your laptop. Also try removing the battery and power up the laptop without the battery but with the adapter connected (could be a battery problem).
4/23/2009 4:32:55 AM •
Gateway...
Answered
on Apr 23, 2009
Laser mouse light won't come on when is used to
If you have a USB mouse, try it on a friends PC or laptop.
if it works there then check your USB (Universal Serial Bus Controllers) in the Device Manager...
right click My Computer
select Manage
select Device Manager
from here you can check you "Mice and other pointing devices, and your USB controllers
Good Luck!
3/29/2009 3:19:33 AM •
Gateway...
Answered
on Mar 29, 2009
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do.
First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button.
Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button.
Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation.
I hope this helps!
3/14/2023 5:41:18 PM •
Gateway...
Answered
on Mar 14, 2023
