20 Most Recent Gateway 7210GX Notebook Questions & Answers
XP is too old to access the internet anymore! MS stopped updating or supporting XP years ago. Any system they stop supporting will eventually not be able to communicate with the internet. Operating Systems(XP) have to be update to communicate with internet upgrades, once that update process stops, your XP or others, will no longer work on internet.
time to buy new pc and windows os, ie. Windows 10
Gateway 7210GX... | Answered on Jan 22, 2019
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Gateway 7210GX... | Answered on Jun 21, 2012
Hi, you can download the driver here:
http://support.gateway.com/us/en/product/default.aspx?partNumber=4092
Please select the one for your windows version.
The driver has to be unziped before installation.
Gateway 7210GX... | Answered on Sep 16, 2011
Remove the screws that are mounted underneath the rubber bumpers. Then carefully pry open the bezel.
Gateway 7210GX... | Answered on Jan 02, 2011
Si es para comprarlo aqui el LINK
Gateway 7210GX... | Answered on Dec 11, 2010
If they are generic Windows drivers, a driver finder program should be able to find the right drivers for that computer.
Gateway 7210GX... | Answered on Jul 19, 2010
If you still have the tab that activates the switch they can sometimes be glued back on. The keyboard cover includes the power button. You can find them on ebay for 1/3 of what the are from a parts depot.
Gateway 7210GX... | Answered on Jul 17, 2010
Bad battery or charging unit. A volt meter can check the charger although the battery is the problem if old I think
Gateway 7210GX... | Answered on Jul 08, 2010
By removing all screws first... Along with unplugging all cables..
Once all screws are removed, The motherboard will pop right out..
Gateway 7210GX... | Answered on Dec 03, 2009
The drivers will only work once you have an operating system installed. ATM your new HDD contains nothing.
Gateway 7210GX... | Answered on Sep 20, 2009
Are you sure the charger is the correct specs for your model? Check the label on the laptop and on the charger to be sure they match. The voltage and amps should be the same. Most importantly check the polarity which will be a graphic that looks something like this:
o)--->+
What that is telling you is if the center of the plug is positive or negative. The only thing that matters is that the pictures are the same. If you switch your polarity you will almost always blow out your power supply on the system board. Does the laptop power on or has it not worked since you heard the noise?
If it has not powers on odds are the specs are wrong on your charger and you might have damaged the laptop. If the laptop still works then it is possible the charger is providing too much power or malfunctioning. A laptop will work with a more powerful charger sometimes, but it is never recommended as it will create more heat and reduce the life time of the laptop system board.
Gateway 7210GX... | Answered on Aug 22, 2009
ADDRESS BAR: PCMCIA MTD-0002 DRIVERS
WWW.DRIVERSHQ.COM/DRIVERS
WWW.WINDRIVERS.COM
WWW.PCMCIA.COM/DRIVERS
MANUFACTURE NAME,MODEL,MAKE DRIVERS.COM
Gateway 7210GX... | Answered on Jul 31, 2009
If you mean by drive the hard drive, any 2.5" laptop hard drive will work. It must be ATA for this model. www.newegg.com is the best place to find computer parts for a good price. I just purchased a seagate 120gb laptop hard drive for this same model computer.
Char S.
Gateway 7210GX... | Answered on May 20, 2009
try to reinstall your audio driver click here to download driver http://support.gateway.com/support/drivers/search.asp?st=pn&param=4092
Gateway 7210GX... | Answered on Mar 12, 2009
Check the connections to your hard drive and make sure the sata and power cables are fully connected. Then listen for the spinning sound. If your hard drive is not spinning it may be bad, or it could be an issue with your connectors, either way i would contact gateway for further support as it should be looked at.
Gateway 7210GX... | Answered on Jan 25, 2009
I found there are plastic clips on the hinges that pop off and from there the face plate comes off. All better now
Gateway 7210GX... | Answered on Jan 23, 2009
Gateway 7210GX Notebook Logo
41 questions posted
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
7210 gx th eon off button contains
  • Computers & Internet
