20 Most Recent Contax Telephoto 85mm f/1.4 Carl Zeiss Planar T* (MM Type) Manual Focus Lens Questions & Answers
Nikon d300s
As the name states, this is a manual focus lens. As such, it does not have autofocus capabilities.
7/29/2013 8:07:33 PM • Contax Telephoto... • Answered on Jul 29, 2013
My contax 167 mt shuts down unexpectedly
Greetings, The batteries would be a good place to start if the camera is having power issues. I see that AAA batteries are used, so you can start with swapping those out. Also, ensure that your camera hasn't recently been dropped or soaked in any type of liquid or exposed to extreme temperatures otherwise internal chips could be harmed. Thank you.
4/24/2023 4:14:12 AM • Contax Cameras • Answered on Apr 24, 2023
What is the difference between a bug and an error
The first physically documented computer bug was documented by Dr. Grace Murray Hopper when she was programming the Mark II Calculator (computer). When the system was not functioning correctly after troubleshooting the system, she found a moth between contacts of a relay. After removing the moth the system functioned and the moth was taped in her notes documenting the bug.
A computer error is displayed when a known problem in the computer code (program) expects a result from the hardware (electronic circuit) or software, and it does not fall within the code parameters. In most cases the error can return information about why the computer had a problem.
Conclusion:
A bug is an unknown failure of the system which usually is intermittent and causes the system to crash or results in some type of failure. An error returns information about the system failure which is displayed or documented on the display or in log file.
7/2/2010 4:41:42 PM • Contax Cameras • Answered on Jul 02, 2010
I have a number of Contax lenses I inherited from
Without adapters, none. Contax shared their CY lens mount with Yashica and both produced fine cameras and lenses but neither manufacturer survived the transition from film to digital so there are no digital cameras which can use them as standard.
With the correct adapter you can mount most of them to Olympus Four Thirds and Micro Four Thirds for certain but some CY lenses may have rear elements which project backwards too far into the camera body. You'll also find that there will be no automatic stop down and no communication of aperture, zoom or focus settings to whichever digital body you fit them to.
Many CY lenses are excellent Carl Zeiss T* units but like almost all old 35mm lenses the optical designs were designed by engineers using slide rules and calculators. Except for the occasional "accidentally good" lens you shouldn't expect the optical performance to match contemporary designs which have the benefit of computer aided design and the latest advances in optical technology. This is especially true at apertures wider than around f8.
You may find adapters from CY to anything else to be hard to obtain/expensive simply due to lack of demand: even at their peak, Contax and Yashica SLR cameras were infrequently encountered and had very low sales volumes.
Although this may all sound negative, my advice is to check ebay for an adapter; many good Chinese sellers offer excellent and cheap adapters but research their feedback. Your lenses should be much better than the average 35mm SLR lenses and if you can accept a few compromises are still capable of producing very good photographs under the right conditions. Alternatively find a good used body like a Contax 139 or Yashica FX-D and scan the 35mm negatives afterwards for best results.
9/4/2009 12:33:51 PM • Contax Cameras • Answered on Sep 04, 2009
2answers
Activition code digital tv 2050
Free version does not require activation, but unsure if that will work for you. Web site specifically states there is not any activation code and not supported. All of its software is "free, freeware, shareware, full version, trial, demo or open-source" https://www.download.hr/software-digital-tv-2050.html
4/15/2024 9:02:35 PM • Cameras • Answered 16 hours ago
INTERNAL ERROR FREEGROMRIGHT SIZE 1431655766
I don't see anything that resembles 'make model (what it is)'. You posted to the category Cameras? https://www.google.com/search?q=FREEGROMRIGHT+SIZE+1431655766 ..
4/5/2024 1:31:05 AM • Cameras • Answered on Apr 05, 2024
2answers
Where can I get Manual for novar ed&s wireless colour camera
if you purchased the camera from a retailer or reseller, they may have a copy of the manual available.
4/4/2024 12:04:13 AM • Cameras • Answered on Apr 04, 2024
How do you turn on Digivue1.3? Has new batteries and used a while ago but pressing 2 button (Mode, Set) do nothing.
This is going to take patience and maybe the user guide. To turn on the Digivue 1.3, follow these steps: Connect to Your PC: Connect the standard USB cable (supplied) to a free USB socket on your PC. The end of the USB cable should be connected to the socket on the back of the USB digidock. Important: Do not connect any of the cabling provided with the Digivue before commencing the software installation. Install DigiConnect Windows® Software: Insert your Digivue into the docking station. If you are connecting for the first time, a Red LED will display in the Activity Window of the Digivue. Insert the CD provided into your optical disk drive. It will run automatically, and a dialog box will appear. If the autorun feature is disabled on your system, browse to the disk using Windows® Explorer and double-click Setup.exe. If you have a multilingual version of Digiconnect, you will be prompted for your language. Select from the list and click "Next." Accept the terms in the License Agreement and proceed with the installation. Choose the folder for software installation (default is the standard location for Windows® programs). Click "Install" to begin the installation. Leave the box labeled "Launch DigiConnect" ticked and click "Finish." Wait for the Red LED: Wait until a RED LED appears in the activity window of the Digivue. You may now proceed with the next steps. If you encounter any issues during this process, refer to the detailed instructions in the Digivue User Guide on page 9
4/1/2024 1:04:02 PM • Cameras • Answered on Apr 01, 2024
Hello, I would like to know how to solve an error called "ALLARME" "sicur camera"??
Reboot everything. If that doesn't work, Maker Support.
SICUR SERVICE ITALIA
SICUR SERVICE ITALIA https://www.sicurserviceitalia.it ·Translate this page 1.3 MP Camera · 2 Mega Pixel Camera · 3 Mega Pixel Camera · 4 Mega Pixel IR Camera · 5 Mega Pixel IR Camera · 12 Mega Pixel Camera · Speed Dome da esterno ... ..
3/15/2024 2:12:47 PM • Cameras • Answered on Mar 15, 2024
2answers
Which is the best weding photographer in ernakulam
Here are some highly regarded wedding photographers in Ernakulam, Kerala:
  1. Maks Wedding Photography:
    • Located inChelad, Kothamangalam, Kerala.
    • Specializes inwedding photography and videography.
    • Contact:099478 23133.
    • Facebook Page
  2. Lumiere Wedding Company:
    • Based in Ernakulam, Kerala.
    • Their crew beautifully captures emotions during the D-day, creating elegant pictures that will remain etched in your heart forever.
    • They cover weddings not only in Ernakulam but also in UAE, Malaysia, and other parts of the globe.
    • Contact:099951 48014.
    • Website
  3. Euforia Wedding Photography:
    • Located atUzhinjelil Tower, Convent Rd, Ponnurunni, Vyttila, Kochi, Kerala.
    • Offers candid and artful wedding photography packages.
    • Cherish the vibrant traditions and colors of your Kerala wedding with their skilled team.
    • Contact:090481 90403.
    • Website
  4. Dakshin Wedding Services:
    • Exclusive wedding photography and videography company covering events across South India.
    • Address:Js 5, 5th Floor, Heavenly Plaza, Kakkanad, Edappally, Civil Line Road, Ernakulam, Kerala.
    • Contact:070123 90551.
    • More Information
Remember to explore their portfolios, discuss your preferences, and find the photographer whose style resonates with your vision for capturing your special day! These companies use teams. It is difficult to pick out an individual photographer but perhaps you might find what you are looking for at the Lumiere Wedding Company. That company stands out among the four I mentioned.
3/15/2024 10:38:43 AM • Cameras • Answered on Mar 15, 2024
Hi, I am in Dubai,I
FUJIFILM MIDDLE EAST FZE [Subsidiary] Business Field (s): Digital Cameras
Address: P.O. Box 17212, R/A08, HB03, Jebel Ali, Dubai, U.A.E.
Tel: 971-4-883-9990
GRAND STORES [Distributor] Business Field (s): Photographic Film and Paper, Film Cameras, Digital Cameras, Digital Printers, Minilab Systems, Medical Systems
Address: Saleh Mohammed Bin, Lahej Building, Al Garhood, P.O. Box 2144, Deira, Dubai, U.A.E.
Tel: 971-4-2-823700
Dynagraph For Printing Industry [Distributor] Business Field (s): Graphic Systems
Address: Al Quoz Industrial Area, Sultan Al Suwaidi Building, Office No.1, Dubai, U.A.E.
Website:
3/14/2024 5:17:47 AM • Cameras • Answered on Mar 14, 2024
Hi, Have replaced batteries on model Gardenline brand model46715 garden timer and there is no digital screen showing on the timer. It is blank, like it needs new batteries.Can you please help me? Russ
Here are some steps you can take to diagnose and potentially resolve the problem: Check Battery Polarity: Ensure that the batteries are inserted correctly, with the positive (+) and negative (-) terminals aligned properly. Sometimes a simple reversal of the batteries can cause display issues. Reset the Timer: Some electronic devices benefit from a reset. Try removing the batteries, waiting for a minute, and then reinserting them. This action might reset the timer and bring the display back to life. Inspect the Battery Compartment: Look for any signs of corrosion or dirt in the battery compartment. Clean it gently using a cotton swab or a soft cloth. Corrosion can disrupt the electrical connection and affect the display. Test with Fresh Batteries: Even if the batteries are new, they might be defective. Try using a different set of fresh batteries to see if the display turns on. Check for a Backlight or Contrast Setting: Some timers have adjustable backlight or contrast settings. If your model has this feature, try adjusting it to see if the display becomes visible. Contact Customer Support: If none of the above steps work, consider reaching out to the manufacturer's customer support. Remember that the Gardenline brand model 46715 has received mixed reviews, with some users reporting issues related to the LCD screen. While some have had positive experiences, others have encountered problems like fading screens or dead displays . If none of this works, you may need to explore another timer.
3/13/2024 2:39:50 AM • Cameras • Answered on Mar 13, 2024
What type of battery does my TVG it has two batteries
All question need 'make model (what it is) as first 3 words or this happens https://www.google.com/search?q=What+type+of+battery+does+my+TVG+have Guessing is is a mobility scooter, but even so. Google know all the answers, your search query would be make model battery replacement Or just look at what is one the existing ones if you have them. Or Google make model manual Everything is online and my skill is finding stuff. ..
3/13/2024 2:19:59 AM • Cameras • Answered on Mar 13, 2024
The pop-up flash does not flash when taking a picture.
'make model (what it is)' is useful in questions like this!
How to fix the popup flash on your camera (Canon DSLR)
Tutorial Geek https://www.tutorialgeek.net > 2013/02 > how-to-fix-pop... Put the camera into Automatic mode and pry your fingernail under the flash (see the photo above). Right now the flash is locked, so you will not be able to ...
Why doesn't my D3100 take photos when the built in flash ...
Photography Stack Exchange https://photo.stackexchange.com > questions > why-doe... Feb 18, 2023 - I have a Nikon D3100. It doesn't take pictures while the built in flash is popped up, but is working fine when the flash is down. What could be ... 1 answer · 2 votes: I'm guessing that the exposure settings are significantly different (darker) when the flash is up because it is expecting the flash to add a lot of light. ... What to do when my pop-up flash doesn't work after being ... Mar 25, 2013 nikon - Why is my dSLR's pop-up flash not firing? Dec 29, 2019 Why won't my D3100 take flash pictures even when focused? Jan 21, 2013 Why doesn't my Nikon D5200 pop-up flash fire in manual mode? Dec 27, 2016 More results from photo.stackexchange.com ..
2/29/2024 7:06:29 PM • Cameras • Answered on Feb 29, 2024
Contax Telephoto 85mm f/1.4 Carl Zeiss Planar T* (MM Type) Manual Focus Lens Logo
1 questions posted
Top Contax Cameras Experts
Tesfay
Tesfay
Lance Strong
Daniel Galmier
Level 1 Expert
Are you a Contax Camera Expert? Answer questions, earn points and help others
View Most Popular
Contax Cameras
  • Contax Cameras
Most Popular Question
nikon d300s
  • Cameras
