20 Most Recent
Gateway At&t 2701hgv-b 2wire Hi Speed Internet Wireless Modem Router Uverse Att Questions & Answers
How to get my 2wire ip number
There is a problem: you are connected on LAN side of the modem, so your IP is privat and are not visible in the Internet. It?s like 192.168.x.x .On the WAN side you have another IP that's could be public: 5.35.85.x .To see the public IP use a specific web site like: http://pingme.info/
Dynex tv won't give me the option to connect to a wireless network. It defaults to wired
This would normally indicate either a compatibility problem, the wireless network is not broadcasting, or you do not have enough signal to see the network. First thing I would try is most devices that can connect to WiFi have the option of connecting to a network that is not listed. I would try that. If that still does not work I would then try disabling all wireless security on the router just to see if that will work(I do not recommend leaving the security disabled any longer than it takes to test this). If none of that works then the next thing would be to check the signal. If you have a laptop, tablet, or cell phone that is connected to your wireless network then bring it over to the tv. If you loose signal, or have low signal then you will need to find a way to get more signal. Even if you do not see low signal on other devices the tv can still have too low signal partly because the antennas are usually in the back where the signal would be blocked by the tv as well as any other equipment you may have around the tv. Try to make sure that there are no metal objects between the tv and the router, and if possible try to get the router as close to directly behind the tv as possible. The more walls the wireless signal has to go through the weaker the signal will be, and metal can reflect the signal, completely blocking it, as well as causing noise on anything near the metal.
Where is the pin number
The P.I.N. is the Personal Identification Number. The user sets the number upon the initial installation. Apparently, you are not the original owner. I would suggest that you contact that person and obtain the P.I.N.Unfortunately, if you set up a PIN or Password lock on the unit, there is no way to unlock it without using the correct input. If you cannot remember the correct input, the equipment must be sent in to Gateway for service to remove the password or PIN.
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do.
First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button.
Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button.
Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation.
I hope this helps!
3/14/2023 5:41:18 PM •
Gateway...
Answered
on Mar 14, 2023
I have a 2017 Gateway All in One Pentium Model zx6980 Push power button monitor comes on faintly No signal HD something. Will not boot
It sounds like there could be a few different issues going on with your computer. Here are some steps you can try to troubleshoot the problem:
- Check the connections: Make sure all cables and connections are secure and properly plugged in. This includes the power cable, monitor cable, and any other peripheral cables.
- Check the monitor: Try connecting your computer to a different monitor to see if the issue is with the monitor itself. If the other monitor works, the problem is likely with your original monitor.
- Check the hard drive: Disconnect the new SSD hard drive and try booting up the computer without it. If the computer boots up successfully, there may be an issue with the hard drive or its installation.
- Check the battery: As you mentioned, the issue could be related to the battery on the motherboard. Try replacing the battery with a new one and see if that helps.
- Try booting into safe mode: If the computer is still not booting up, try booting into safe mode by pressing the F8 key during startup. This will allow you to troubleshoot any issues with your computer's software.
If none of these steps resolve the issue, you may need to take your computer to a professional for further diagnosis and repair.
2/26/2023 7:02:04 PM •
Gateway...
Answered
on Feb 26, 2023
I need a gateway laptop recovery cd
Gateway does not provide recovery CDs for their laptops. Instead, they provide a recovery partition on the hard drive that can be used to restore the laptop to its original factory settings. To access the recovery partition, you will need to press a specific key or combination of keys when the laptop is first turned on. This key or combination of keys will vary depending on the model of laptop you have. You can find instructions for accessing the recovery partition in the laptop's user manual or on Gateway's
2/21/2023 10:42:44 PM •
Gateway...
Answered
on Feb 21, 2023
