20 Most Recent
Gateway Sb-4100-A PC Desktop Questions & Answers
When turning on Sb-4100 I get message
Hi rbrown454. That file is for your HP printer. Go to hp.com and click on support and drivers and download the latest driver for your printer. While it's downloading go to add/remove programs in Control Panel and uninstall ALL HP software. Do not restart, wait for the software to finish downloading and restart. Then reinstall the software you downloaded from the internet.
In case you have the CD, reinstall the CD but make sure you uninstall ALL HP Software.
I hope this helps. Please do not forget to rate and provide positive feedback for our fast/free support today. Thank you :D
5/10/2010 5:16:06 PM •
Gateway...
Answered
on May 10, 2010
System wont boot up
operating system already corrupted, your need to re install your operating system from cd installer, you can keep your existing file by selecting no to format.
3/23/2010 3:23:21 AM •
Gateway...
Answered
on Mar 23, 2010
Computer won't boot, it loops over and over.
Sounds like corruption in the registry. Have you tried booting in safe mode? Try hitting the F8 key on boot and see if you can get it to boot in safe mode.
Cheers,
Ripface.
9/25/2009 8:39:56 PM •
Gateway...
Answered
on Sep 25, 2009
NO AUDIO
The reason to this problem is due to the audio driver.so you
need to install the audio driver.
9/2/2009 6:22:59 PM •
Gateway...
Answered
on Sep 02, 2009
Gateway e-4100 thermal event
There can also be thermal sensors in your power supply, on your motherboard, and video card. Does your problem happen during gaming/heavy computing, after x amount of time, or totally randomly?
If your case conforms to the later ATX spec or some derivative thereof, don't block the hole in the side of the case.
Just some stuff I've run into, maybe you already know this!
11/25/2008 5:42:57 AM •
Gateway...
Answered
on Nov 25, 2008
pull the black clip on the back up
then use the little indented circles on each side and press in and pull up
once inside switch three green tabs to show red.... then lift up the back metal base up and it will pull away from the RAM area
5/22/2008 12:07:34 PM •
Gateway...
Answered
on May 22, 2008
Gateway sb-4100-b won't recognize new memory
Check the owners manual of your computer for the correct installation of 2 sticks of memory, this can be critical on computers with 2 banks of 2 slots, it will also tell you the maximum ram that will work. If you do not have the manual, go to the manufactures website and then go to the support link, and browse for memory installation. BPCS
5/1/2008 2:56:25 AM •
Gateway...
Answered
on May 01, 2008
System recovery Floppy
you can purchase locally a usb floppy drive and download some small utilities in the internet that can be fit in the floppy disk, but i suggest that better use memory stick because it is cheaper and you can have more space than floppy disk.
3/31/2008 2:09:57 PM •
Gateway...
Answered
on Mar 31, 2008
Gateway E4100 Mid Tower RAM install
no need to install RAM in pairs.
you can buy and install memory but it should be the same model that you have now e.g. DDRII RAM Modules.
you can max out the RAM 4 gigs
3/31/2008 1:06:41 PM •
Gateway...
Answered
on Mar 31, 2008
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do.
First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button.
Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button.
Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation.
I hope this helps!
3/14/2023 5:41:18 PM •
Gateway...
Answered
on Mar 14, 2023
