20 Most Recent Gateway Essential 500 PC Desktop Questions & Answers
What is the password for Gateway Essential 566c Desktop PC
if you are able to open the pc open it. Remove the cmos battery and turn on the pc and again turn of the pc and install the battery again. if it doesnt work try to locate the cmos jumper on the mother board and clear the bios
12/27/2015 8:37:24 AM • Gateway... • Answered on Dec 27, 2015
What is the password for Gateway Essential 566c Desktop PC?
You have to remove the CMOS battery located in your motherboard. Open your desktop casing and look for the battery 24512684-rjwieg52o3iw43rovx0iip2o-3-2.jpg
2/16/2015 7:59:56 AM • Gateway... • Answered on Feb 16, 2015
On the 2nd harddrive does the jumper go on slave or cs position
Seconary hd goes on slave.
2/13/2013 9:46:12 PM • Gateway... • Answered on Feb 13, 2013
I can't download anything.
Are you using Internet Explorer? Just go to the top of the screen with your mouse and RIGHT click on the very top part of the screen. It should bring up a small menu, look for Menu Bar, and LEFT click beside it (it will put a small check mark beside it to show that the option is enabled). You can show or hide many of the info bars along the top with this method. If you pick one that you dont want anymore, just open the menu again and click on the check mark to unselect it. Did this help?
2/3/2013 7:02:39 PM • Gateway... • Answered on Feb 03, 2013
0answers
Need manual for essential gateway 500c
try here :http://support.gateway.com/s/Manuals/Desktops/8510158.pdfdid this help?
1/5/2013 3:31:04 PM • Gateway... • Answered on Jan 05, 2013
Gateway essential 500 blinking cursor, how do i uninstall windows i have a windows 98 to put in will that work?
Yes, but does the system see the hard drive? Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
11/23/2012 5:17:27 AM • Gateway... • Answered on Nov 23, 2012
How do you set the system date and time
To set the Date & Time, go into the BIOS setting - date 7 time.When you set the Date & Time and you get this error again when you next boot up your computer, then most likely you have a flat BIOS battery.Then replace this battery, it could be a coin size battery - 3 volt lithium battery type CR2032. and then go into the BIOS setting and set the Date & Time.
10/23/2012 5:42:37 AM • Gateway... • Answered on Oct 23, 2012
2answers
No sound coming from new hp monitor through windows vista
Alright, I got the answer for ya, first, go into your control panel. Click on Sounds and Audio Devices. Listed in this window should be the name of your sound card. Under that, should be Device Volume, and at the bottom, should be the Speaker Settings, click into Advanced, next to speaker volume. It should show you a diagram of a monitor with the amount of speakers it has selected shown next to it. Where it says Speaker Setup, click and then scroll down until you see 3 settings labeled Monitor Stereo, Monitor Stand Stereo, and Monitor Mounted Stereo. Whatever one enables the sound will be the one you want to stick with.
9/6/2012 11:16:35 AM • Gateway... • Answered on Sep 06, 2012
2answers
I got A gateway essential 500 from a goodwill
Any EIDE (non Sata) interal drive should work on this computer. However, first I would check the internal cables on the drive to ensure the are plugged in tight (you may just have a loose cable). Check both the mother board end and the drive end.
Personally I would go puppy linux over 98, but that is me.
Hope this helps, have a great day and good luck.
7/25/2011 2:45:53 PM • Gateway... • Answered on Jul 25, 2011
I have a Gateway model
After re-installation of Windows XP operating system on a desktop computer, the only icon that is normally present on the desktop is for the "Recycle Bin"
You will have to move the other icons like "My Computer" and "My Documents" to the desktop. To do this use these steps:
1) Click on the Start button.
2) Then Right-click the "My Computer" link (see attached image) and select "Show on Desktop" from the menu.
3) Using the above steps, move the "My Documents" icon to the Desktop.
If you have lost/misplaced the driver disk, you can download the latest drivers from the manufacturer's support website by clicking this link
Other softwares and programs (which you were using prior to re-installation of Windows XP) will have to be downloaded and installed seperately.
For more help and clarifications, please feel free to reply to this post.
Hope this solves your problem. Thanks for using FixYa.
6/11/2011 2:09:52 PM • Gateway... • Answered on Jun 11, 2011
I WANT TO KNOW HOW
If your additional Hard drive is SATA use SATA cable and SATA power to get it done.
Or else use IDE and D type power to connect.
Make sure that you have switched off the computer before installing the HDD
Thanks,
Satheesh
1/21/2011 3:05:01 AM • Gateway... • Answered on Jan 21, 2011
Gateway 500 desktop pc 133 ram drivers for xp
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, Driver downloads and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
1/6/2011 2:18:42 PM • Gateway... • Answered on Jan 06, 2011
I have a gateway 500c
Well I am sorry to tell you BUT the reason your PSU Failed, is because your CPU has Failed. You see PSU do NOT usually spontaneously fault,most often something causes them to "Blow". In this case it looks like your CPU. As these wires directly feed the Processors high Volts rail. If NOT exactly the CPU, it is something to do with the power circuit suppling it. In any event the processor will be dead. You MAY be able to recover the MB, but you are taking a risk, as if you plug in a NEW CPU,and the faults,ON the Motherboard you will destroy that CPU too. The reason as you say "it\'s like the power was shut down.: (sic) Well that's because thats exactly what is happening, the PSU, senses the fault, and the protection circuitry, shut the PS down. for safety reasons.
It is my professional opinion that you obtain a NEW MB & CPU.You may also find, your RAM, has been damaged too,so be careful here as well.
This is an unfortunate event, but I see many many a week in my shop. if thats of any consequence.
8/13/2010 11:49:14 PM • Gateway... • Answered on Aug 13, 2010
How to install upgrade sdram 128 pc133 for gateway
INSTALLATION PROCEDURE
1. Place the computer's power switch in the "off " position and disconnect the AC power cord. 2. Remove the computer's top cover following the instructions in the model-specific owner's manual.
3. Before touching any electronic components, make sure you first touch an unpainted, grounded metal object to discharge any static electricity stored on your clothing or body.
4. Locate the memory expansion sockets on the computer's motherboard. If all the sockets are full, remove smaller capacity modules to allow room for higher capacity modules.
5. Handle your new module's carefully; do not flex or bend the module(s). Always grasp the module by its edges.
6. For some installations, DIMM memory can be installed in any available expansion slot. Other installations may require the memory to be installed in a particular sequence based on the modules capacity. Check your owner's manual to determine the correct installation sequence for your configuration.
  • Insert the module into an available expansion socket. Note how the module is keyed to the socket. This ensures the module can be plugged into the socket one way only. Firmly press the module into position, making certain the module is completely seated in the socket. Repeat this procedure for any additional modules you are installing.
  • Most 168-pin DIMM modules have ejector tabs. The ejector tabs are used only when you need to remove a module. By pressing down on the ejector tabs, the module will pop-up from the socket and it can be removed.
    7. Once the modules have been installed, the computer's top cover can be reinstalled.
    8. Plug in the AC power cord and reinstall any cables disconnected during the installation process.
    9. Turn on the computer and follow the instructions in your computer owner's manual that describe the steps necessary to allow your computer to recognize the newly installed memory.
    6/22/2010 5:03:10 PM • Gateway... • Answered on Jun 22, 2010
    Computer turns on and works fine once turned off
    If you just hit the button, it's probably set to suspend. You should be using the shutdown procedure, or alt-F4.
    6/18/2010 5:49:38 AM • Gateway... • Answered on Jun 18, 2010
    One speaker has some volume the second speaker has
    uninstall the sound driver from device manager and restart the computer. it will reinstall the default driver on the computer. also check the properties of the sound in the control pannel. double click the icon in the properties and sound window will open then check the settings for the left and right speakers. check the sound wires of speakers if its a external speakers.
    5/13/2010 4:00:13 AM • Gateway... • Answered on May 13, 2010
    PC 133 Max ram for your model is 512MB - two 256 Memory sticks. Open the case, remove the menory in there (one clips on the side of each module) take note of the way the module comes out - replace with your new ones - reboot and that should be that.
    5/10/2010 1:17:30 PM • Gateway... • Answered on May 10, 2010
    Gateway Essential 500 PC Desktop Logo
    54 questions posted
    Top Gateway Computers & Internet Experts
    Steve Nordquist
    Steve Nordquist
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    • Gateway Computers & Internet
    Most Popular Question
    gateway essential 500 blinking cursor
    • Computers & Internet
