20 Most Recent Gateway 832GM PC Desktop Questions & Answers
Hi
This sounds like a memory or a CPU error
Cliff
MCP
Gateway 832GM PC... | Answered on Aug 24, 2014
Click "Start" on your Windows desktop. Navigate through "All Programs" and "Gateway." Click on "Gateway Recovery Management."
Click "Restore" when the Gateway Recovery Management window pops up, which will take the system back to the default factory specifications.
A box will pop up asking for confirmation, click "Yes" and then "Start." You may have to enter a password as well, but only if your particular Gateway had a password set.
Wait for the computer to restart. A "Restore from factory default" box will appear, requiring you to click "Next" twice in a row. Click "OK" in the box that appears next, and wait for the hard drive partition to be created.
The factory default installation will then be moved over to the hard drive.
Click "OK" in the box that appears and wait for a second Gateway restart.
Several minutes will pass as Windows "starts for the first time."
When restarting finally finishes, a "Set Up Windows" dialog box will appear. Click "Next," followed by checking the license agreement box, and then "Next" again.
Enter a user name and picture, if desired, and a computer name. Also, customize the background wallpaper for your desktop, optionally. Click "Next."
Click "Use Recommended Settings" on the Protect Windows-based dialog box that pops up.
Set your correct date and time settings in the next box. Select your location in the following screen. Click "Next," followed by "Start" to finish.
Wait while Windows checks for your individual Gateway computer specifications and adjusts accordingly.
This will likely take several minutes, so leaving your computer for a short time is fine.
Windows will then prepare your hardware and finish your Gateway restoration process, including the installation of Gateway Recovery Management.
Once completed, your Gateway is good to go and ready at factory settings.
hope this helps
Gateway 832GM PC... | Answered on Sep 09, 2012
Good day!
you can thoroughly scan the entire system using an anti virus software to get rid of the virus:
i can refer you to use a avg anti coz it can do internal and extral scan into your software,including your system file and data link libraries.
if you have deeper question about anti virus and virus, kindly pm me.
follow this link for anti virus official website: http://www.freeavg.com/?lng=ph-en&cmpid=corp
happy scanning....=)
Gateway 832GM PC... | Answered on Feb 02, 2012
Hi Leon,
Try updating your media players to the latest versions.If its a download video,try downloads of the same from another source.
Hope this helps.Thanks!
Gateway 832GM PC... | Answered on Dec 14, 2011
Hello Sir,
downloading speed depends on internet connection not on PC specification.
If your transfer is low then downloading will also be low.
Take note that source from which you are downloading also must have reliable connection.
cheers,
Mike
Gateway 832GM PC... | Answered on Jul 01, 2011
did you compress your c drive? sounds like you have, I think you may need to do a re-install.
One thing that may work, would be to install the drive in qustion as a second drive on another machine and you may be able to uncheck the compress disk contents box that way.
Gateway 832GM PC... | Answered on May 05, 2011
at facebook klik forgot password, then answer security question, and your account detail will send to your email
i hope this helpfull
please rate my answer
thanks for using fixya
Gateway 832GM PC... | Answered on Dec 08, 2010
Most likely what you will want to do is just turn your resolution down to it's lowest settings. and turn off unplug the computer and install the card. Plug the monitor into the card and then boot up the computer. Sometimes depending on the computer you may have to disable the onboard video in the bios but a lot of times you don't. If you do run into an issue you can unplug the card hook the monitor back up the onboard video, then if need be disable the onboard driver, by going to control panel, then system properties, then device manager and then under video adapter disable the drivers for the onboard video but it shouldn't be necessary.
Thank you,
Lee
Scan your entire system using chkdsk after the installations then proceed to hard drive defragmentation and reboot system unit.
Gateway 832GM PC... | Answered on Aug 21, 2010
Hi, I need full descrition of problem to help you, but try booting in safe mode, by pressing the ESC or Del key during bootup. From here you can reset your system to a time before problem started.
Gateway 832GM PC... | Answered on Aug 03, 2010
change your disk drive
Gateway 832GM PC... | Answered on Jun 30, 2010
Try starting in safe mode. If it works then you need a graphics driver.
Gateway 832GM PC... | Answered on Jan 01, 2008
The 502 Bad Gateway error is an HTTP status code that means that one server on the internet received an invalid response from another server. 502 Bad Gateway errors are completely independent of your particular setup, meaning that you could see one in any browser, on any operating system, and on any device.
Re boot the computer and router then try again later.
Gateway... | Answered Yesterday
A Payment Gateway is a middle-man that securely takes money from your customers and sends it to your bank account. ... Merchant securely transfers order information to the payment gateway. The transaction is then routed to the issuing bank or the 3D secure page to request transaction authentication.
https://www.quora.com/How-do-payment-gateways-work-technically
Gateway... | Answered on May 10, 2020
A 504 Gateway Timeout Error indicates that a web server attempting to load a page for you did not get a timely response from another server from which it requested information. It's called a 504 error because that's the HTTP status code that the web server uses to define that kind of error.
https://www.howtogeek.com/367129/what-is-a-504-gateway-timeout-error-and-how-can-i-fix-it/
Gateway... | Answered on Apr 15, 2020
it's easy to burn music into a cd
first make sure that your computer has a cd-r or cd-rw drive
second insert a blank cd-r or cd-rw into the drive
third find the music files you want to burn onto the cd
forth open my computer and start dragging the files onto the cd icon on my computer
once you have finished dragging your files open the cd on my computer and click on write files to cd,
Gateway... | Answered on Mar 31, 2020
You need to use blu ray software to play blu rays, i.e. PowerDVD 8 or later, as well you may need additional software such as AnyDVD to watch it.
Gateway... | Answered on Mar 12, 2020
Gateway 832GM PC Desktop Logo
14 questions posted
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
greetings gateway 832gm media center
  • Computers & Internet
